Go Back   HeliFreak > R/C Helicopter Support > Outrage RC > Outrage 550
Outrage 550 Outrage 550 Helicopter Factory Support Forum
Old 04-03-2010, 03:36 PM   #1
LONEWOLF2440
Default Battery
How far back are yall putting the battery. ( Flush with the front or far back? )
LOGO 600 VBAR TREX 700LE
JR 9303 2.4
ILL BE YOUR HUCKLEBERRY!
LONEWOLF2440 is offline        Reply With Quote
Old 04-03-2010, 03:39 PM   #2
Slyster
Depends on weight. But never flush.
Here... my finless imitation.. based on a 25C 5000 6s pack
It's not just a hobby... it's a lifestyle!
Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo
Pete Team Outrage.
Slyster is offline        Reply With Quote
Old 04-03-2010, 03:48 PM   #3
LONEWOLF2440
Thanks im using the outrage 5000 mah
JR 9303 2.4
Old 04-03-2010, 04:04 PM   #4
DominicD
The Capi - HF Support
Mines about 1/2 inch out.
SAB Heli Canada / RotorQuest/Compass
Team KBDD
DominicD is offline        Reply With Quote
Old 04-03-2010, 04:21 PM   #5
LONEWOLF2440
Thanks capi
JR 9303 2.4
Old 04-03-2010, 04:34 PM   #6
DominicD
Its easy to determine where yours should go, remember you are moving the battery forward or back to balance the CG.
Team KBDD
Old 04-04-2010, 05:53 PM   #7
Dogpatch
I too had to relieve some frame for battery slide back clearance. And then have it 3/4" hanging out the nose for CG. And still -I think this bird is tail biased heavy a tad. 100 Ice and ProBec aft and the giant Quark forward on the forward tray. Not a fair trade. Aft heli CG-- nowhere near as important as a real airplane, or a model I suppose.
Dogpatch is offline        Reply With Quote
Old 04-04-2010, 06:15 PM   #8
Andyzboy
I had to dremel away some of the frames, instead of them slanting down I just cut them straight back. Battery sticks out about 1 inch. I run a 2s 1800 pack up front for the reciever, my esc is back by the motor
Andy Cardinal
Compass Models
Gens Ace/Hobbypartz
7HV, Warp 360
Andyzboy is offline        Reply With Quote
Old 04-05-2010, 12:24 AM   #9
s0laris
Heli CG is actually quite important when you arew doing more advanced moves.. Having everything balanced makes life easier when flying!
Outrage 550, Goblin 630, 700, warp 360, Dual BL Mcpx, 130x
**When you start to be in complete control reflexes are not a requirement.**
s0laris is offline        Reply With Quote
Old 04-05-2010, 02:05 PM   #10
Dogpatch
I understand CG is important-- but aft in an airplane is about deadly, from stall/spin recovery is all I meant.
I guess the bat can sit out front until the canopy won't go on? Just don't lawn dart. I'd hate to add lead. I could do carbon tail blades instead of bright orange heavys I suppose.
Old 04-05-2010, 02:09 PM   #11
Slyster
My carsh.. I lawn darted SO hard there was so much dirst packed into that whole in that bottom canopy hole I couldn't remove the canopy... I used pliers to grab hunks of grass.
Battery was deformed slightly.. but fine!
I mean.. if I was TRYING to taco the lipo.. I would have done the exact same crash...
Pete Team Outrage.
Old 04-05-2010, 06:26 PM   #12
Rob43
Default Battery position for CG
Also depends on the battery. Several are using the Turnigy 30C 6S5000. For that, about 1/2" like other say. Also depends on the canopy. My particular Canomod seems a bit heavy compared to the stock lid, so naturally, the battery rides a touch further back with it compared to stock. Not much hanging over the front with it...maybe 1/4". I have the CC Pro BEC riding on the side opposite the ESC below the motor.
= R
b43 =
Team Compass Support
Rob43 is offline        Reply With Quote
