Go Back   HeliFreak > R/C Helicopter Support > Electric Micro/Mini Helicopters > Zoom/Shogun 400
Zoom/Shogun 400 Electric - Zoom - Shogun 400 Specific Discussion
Old 12-15-2006, 10:04 PM   #81
borneobear
Better pics and lower inverts. :wink:
borneobear is offline        Reply With Quote
Old 12-15-2006, 10:05 PM   #82
borneobear
Grass cutting with heli gets you this:
Old 12-15-2006, 10:06 PM   #83
borneobear
Oh well.
Old 12-16-2006, 09:41 PM   #84
borneobear
Well, I didn't think there was much more mods to do. But I guess this will never end. :?
Anyway, I'm using this to mount my motor:
Which leaves me the original shogun motor mount to mod. I basically just cut it off at the yellow line and made two holes at the red dots:
Old 12-16-2006, 09:44 PM   #85
borneobear
I then flipped the two servo mountings over (the original front alum mount is now used to mount the motor mount - does that make sense?)
Anyway, I now have to front holes for my next mod (arrow):
Old 12-16-2006, 09:49 PM   #86
borneobear
With these front mounting holes, I intalled a square alum plate (red arrow) that I bent at about 45 degrees. Mounting was via two nuts and bolts:
I also added a support CF plate (?) - black arrow.
Old 12-16-2006, 09:51 PM   #87
borneobear
The whole purpose of this was to make an elevated battery mount:
Which functions likes so:
Old 12-16-2006, 09:54 PM   #88
borneobear
By elevating the battery higher, my horizontal center of gravity shifts higher. As I understand it, the closer the C of G is to the tail boom line, the easier it is to roll the heli.
Well, I don't know is this is the way to check horizontal C of G, but here's how I do it:
Hang the heli as close as possible to the tail boom line - by the main gear : :mrgreen:
And I find my head side is now slightly heavier:
Old 12-16-2006, 09:57 PM   #89
borneobear
I noted three improvements by doing this mod:
1) Its now very easy to install and take out the Lipo batt due to is being closer to my canopy opening:
2) My canopy now does not carry any of the lipo weight - therefore I can grind down the canopy further to lose weight.
and 3) I DOES ROLL BETTER!!!!
I love this hobby. :wink:
Old 12-17-2006, 02:00 AM   #90
borneobear
A vid of the CCPM mechanism: layout & movement:
Old 12-22-2006, 10:22 AM   #91
borneobear
It feels real weird not having anything else to do -mechanically - to this bird. Its flying perfectly.
I'm bored.
Anyway, Chopchop at RCGroups posted this wiring diagram to improve power distribution:
Original post:
http://www.rcgroups.com/forums/showp...9&postcount=23
Old 12-22-2006, 10:27 AM   #92
borneobear
I modified it very very slightly to improve it further. The wiring basically involves A, B and C. "A" is to improve Earth by having an additional wire to the negative return. B is to improve positive (volt/power) to the two servos which work hardest at keeping the heli up in the air and another to the gyro (also power hungry). And C is where all the positive points from the servo to the BEC meet up.
Very simple really.
Will post pictures of the set up.
Happy flying.
Old 01-09-2007, 07:52 AM   #93
borneobear
ENUFF SAID.
Old 01-09-2007, 08:00 AM   #94
borneobear
Well, I haven't posted much mods lately. Mainly cuz there hasn't been any. Which I think is a good sign that my model has finally reached its equillibrium.
I did however run into a weak spot yesterday:
The arrow above points to my servo arm connected to the push-pull rod. I'm using an aircraft connector (easy to adjust rod lenght). Where this connector is bolted to the plastic servo arm, I found tons of BINDING.
Old 01-09-2007, 08:04 AM   #95
borneobear
Here's the offending item:
The plastic hole where the connector is bolted to binds it as its bolt is tightened. If it is tightened too much, it will bind more, while if I tighten too little, it starts to wobble.
Old 01-09-2007, 08:14 AM   #96
borneobear
Here's the solution:
I use these copper bushings that were lying around my tool box.
Old 01-09-2007, 08:16 AM   #97
borneobear
I can't recall where they came from, but I think it was from my original #36 bird's see-saw arm support:
Old 01-09-2007, 08:20 AM   #98
borneobear
All I had to do was file the copper bushings to exactly the height of the servo arm, drilled a hole JUST big enough for it to be pushed in. Here's the end product:
Old 01-09-2007, 08:26 AM   #99
borneobear
By lining the servo arm with copper bushing, I feel very little binding of the servo rod connector.
Obviously to get rid of all the binding - bearings should be used. But I don't have that size at the moment. Another way would be to use servo ball links.
But for now, I'm happy with my copper bushings.
Happy flying! :wink:
Old 01-14-2007, 07:49 AM   #100
borneobear
Flying in the highlands of Borneo...
