Go Back   HeliFreak > R/C Helicopter Support > Outrage Velocity 90 Nitro
Outrage Velocity 90 Nitro Outrage Velocity 90 Nitro Helicopter Factory Support Forum
Old 04-08-2010, 11:24 AM   #1
Charley Stephens
The most interesting man in the world
Default Velocity 90 Build
Well Fella's,
The first of the prototypes has arrived and I will be posting the build all day today So check back periodically to see the latest
Ultra rigid CNC rotor head design features:
• Fully adjustable rotor head ratios for Beginner to Advanced 3D or FAI/F3C flying
• Triple radial and single thrust bearing per main blade grip
• 90 degree achievable geometry with all grip ratios
• Ball raced spindle driver for precision flap control
• Special shouldered spindle bolt for increased strength and fatigue resistance
• Dual ball bearing seesaw support
• Ball raced washout base for slop free phasing
• Ball raced radius arms
• 120/140 degree Swash plate features double ball bearing with Interchangeable swash plate upper cup for flybar or flybarless head
Ultra rigid and compact frame design features:
• Ball raced anti-rotation "A" arm control on elevator
• Dual ball raced and bridged clutch bearing block
• Direct drive start shaft
• Triple main shaft bearings
• Gyro compartment for increased protection
• Flexible electronics mounting options
• Injection molded plastic canopy break always
• Collarless main shaft locking design
• Counter balanced fuel tank design with easy serviceable external fuel fittings
• 3 piece engine mount design for easy install/removal
• Large heavy duty clutch system
• Rear frame doublers for increased strength
• Rigid mount boom support design
• Adjustable servo mount for all servo ports
• Bell crank zero pitch alignment system with locking tools for easy and accurate servo to swash linkage setup
• Ultra compact high volume cooling system
• 140 degree CCPM (Optional)
• Individually removable and replaceable torque tube gears
Ultra compact tail rotor system:
• Semi enclosed all CNC tail case and hub
• Single side plate for easy gear access and reduced parts count
• 6mm tail shaft
• Individually removable and replaceable bevel gears
• Ball raced double hinged precision tail system
• Double ball raced grip links
• Double ball raced with thrust bearing Tail blade Grips
So let the pics begin
ID:	150077   Click image for larger version
ID:	150104   Click image for larger version
ID:	150105   Click image for larger version
ID:	150106   Click image for larger version
ID:	150114   Click image for larger version
ID:	150115   Click image for larger version
Name:	head assembled.jpg
ID:	150116   Click image for larger version
ID:	150131   Click image for larger version
ID:	150133   Click image for larger version
ID:	150134   Click image for larger version
ID:	150135   Click image for larger version
ID:	150136   Click image for larger version
Charley Stephens
Rotorworkz
Charley Stephens is offline        Reply With Quote
Old 04-08-2010, 11:29 AM   #2
beeflyer2
Team Synergy
beeflyer2 is offline        Reply With Quote
Old 04-08-2010, 11:34 AM   #3
Eric Brandenburg
OH HELL YEAH!!!
Give me a lever long enough and I'll move the world...
):> Team Helifreak!
Eric Brandenburg is offline        Reply With Quote
Old 04-08-2010, 11:53 AM   #4
Foxden
You Bet, Marathan build baby
Man that head looks sweat..
Looks like we are going to need an Outrage Velcoity 90 Forum now
Clyde Fox
Port Charlotte, FL.
Team Rotorworkz/Outrage
Foxden is offline        Reply With Quote
Old 04-08-2010, 11:59 AM   #5
R0t0R
Yes!!! Will be checking in to see the progress! Don't even need to see it fly. With the way all my other Outrage helis fly, put me down for a pre-order Charley!
Time to add a Velocity 90 sub-forum???
Team Outrage RC
R0t0R is offline        Reply With Quote
Old 04-08-2010, 01:05 PM   #6
howardm4
Please specify a harder plastic and higher quality aluminum than the V50 has.
Those are my only V50 pet peeves (and yea, fix the fuel tank )
howardm4 is offline        Reply With Quote
Old 04-08-2010, 02:13 PM   #7
Charley Stephens
More pics
ID:	150152   Click image for larger version
ID:	150153   Click image for larger version
ID:	150154   Click image for larger version
Charley Stephens
Rotorworkz
Old 04-08-2010, 03:25 PM   #8
John Cook
Location: Winnebago IL Where the politicians are MORE corrupt-Thanks alot Blago/Burris/Daley etc...
Team Alees
Scorpion Power Systems/Batteries
John Cook is offline        Reply With Quote
Old 04-08-2010, 05:17 PM   #9
onequick96gt
Oh yeah baby! More pics please, Im drooling!
Aaron Johnson
Synergy/Botos Design and Distribution
YS Engines/Hatori
Byron Rotor Rage
onequick96gt is offline        Reply With Quote
Old 04-08-2010, 05:23 PM   #10
Foxden
From what I can see in the pic, vent line outside and inlet is also on the outside of the tank, easy access
Clyde Fox
Port Charlotte, FL.
Old 04-08-2010, 05:24 PM   #11
DominicD
The Capi - HF Support
Charley is that a BB guide i see in the washout for the anti-rotation pins ?? If so you are a genius !!!
BTW, You don't have to build my prototype, just send it to me
SAB Heli Canada / RotorQuest/Compass
Team KBDD
DominicD is online now        Reply With Quote
Old 04-08-2010, 05:27 PM   #12
onequick96gt
^---LOL
Aaron Johnson
YS Engines/Hatori
Byron Rotor Rage
Old 04-08-2010, 05:30 PM   #13
Charley Stephens
Haha Yes Good catch yes the washout base is ball raced
Charley Stephens
Rotorworkz
Old 04-08-2010, 05:33 PM   #14
onequick96gt
OK, now that is simply BAD a$$!
Aaron Johnson
YS Engines/Hatori
Byron Rotor Rage
Old 04-08-2010, 05:34 PM   #15
DominicD
LOL Let the copying begin ! No wonder you were so tight lipped about the 90 photos.
Team KBDD
Old 04-08-2010, 05:36 PM   #16
Charley Stephens
There are many other killer features not yet seen in pics...
wait until you see the side by side with 50 it looks like another 50
Charley Stephens
Rotorworkz
Old 04-08-2010, 05:38 PM   #17
DominicD
You are killing me Charley, all i need now is Clyde's home address and work schedule
Team KBDD
Old 04-08-2010, 05:50 PM   #18
kazager
When will we start hearing pricing info? Spring is only so long...Can't wait, I showed the wife and she sighed!
kazager is offline        Reply With Quote
Old 04-08-2010, 05:52 PM   #19
Wurger
LUST
Say ... there looks to be an outrage towel now too! So when I buy a 90, I dont have to build it on an align towel like I did my Velocity 50.
Wurger is online now        Reply With Quote
Old 04-08-2010, 06:05 PM   #20
wicked_n_raw
Ok now I am hooked
Best Regards
Furron
Goblin, Pulse Ultra, Canomod
wicked_n_raw is offline        Reply With Quote
