Old 04-08-2010, 01:22 PM   #1
gkfasciano
Default no throttle?
I went to test my heli after days of adjusting and my motor does not appear to be working. I checked throttle hold switch and its off. Any other possibilities?
gkfasciano is offline        Reply With Quote
Old 04-08-2010, 02:13 PM   #2
rotormonkey
Plug a servo into the receiver's throttle channel and see what it does. If it doesn't move, there's something wrong with your radio programming. If it does, then look at the ESC. I assume that your servos are all working fine? It's just the throttle? I'll also assume that your motor is plugged into the ESC?
rotormonkey is offline        Reply With Quote
Old 04-08-2010, 03:53 PM   #3
gkfasciano
All I get when I raise the throttle stick is 3 servos moving up the swash plate(which is correct) except there is no motor sounds or blades spinning. Where in the programming would I look for an error? Keep in mind Im really new at large heli's so there is a wealth of dumb questions I may ask. Thanks.
Old 04-08-2010, 04:18 PM   #4
Altec
Did you plug a servo into the throttle channel yet to see if it moves?
-you can't FIX stupid-
AMA# 935732
Altec is offline        Reply With Quote
Old 04-08-2010, 04:59 PM   #5
Ozz58
Re-bind!
Ozz58 is online now        Reply With Quote
Old 04-08-2010, 07:08 PM   #6
n3mnt
Is your throttle control stick all the way to zero when you connect power( battery) to the ESC. Most ESCs have a safety mode that will not allow them to initialize if the throttle is not a zero when power is connected. Check your throttle curve o make sure you have dead low stick giving you zero throttle.
n3mnt is offline        Reply With Quote
Old 04-09-2010, 10:42 AM   #7
gkfasciano
I did, and I got the servo to move. Also I plugged the speed control into the servo empty servo channel just for a power source, and the rotor came alive when I moved the appropriate stick. By the way when I have all the plugs in correctly and have the transmitter on I get a lot of random beeping from the speed control. Any suggestions? Thanks a lot for the help.
Old 04-09-2010, 10:43 AM   #8
gkfasciano
Checked it, and the stick is in the dead low position. I think its the speed control.
Old 04-09-2010, 10:44 AM   #9
gkfasciano
Thanks, I did but that wasn't it.
Old 04-09-2010, 10:55 AM   #10
gkfasciano
Checked the throttle curve which I haven't gotten to yet in the setup, but this is what it says
NORM says "pos 3"
STUNT
HOLD 50.0%
Then when I scroll to HOLD it changes to 4.0%
