Go Back   HeliFreak > R/C Helicopter Support > Electric Micro/Mini Helicopters > Zoom/Shogun 400
Zoom/Shogun 400 Electric - Zoom - Shogun 400 Specific Discussion
Old 08-05-2004, 07:35 AM   #1
WillJames
Registered User
Default 400DH 9T Pinion Install for Zoom
Hi Guys,
After trying to figure out how to install a pinion and reading through EZone for an hour or more on the subject.....
Last night when I went to Shannon's to work on my night rig I got him to show me how to install a pinion. What he did was to heat the pinion a little bit with his mini torch, suppot the other end of the armature shaft on the back side of the motor with a big punch, and the hot pinion tapped right on. MUCH easier than I ever imagined. Glad I got help.
Thanks Shannon!!!
William James
WillJames is offline        Reply With Quote
Old 08-05-2004, 07:50 AM   #2
Sar
You can press them together with a vice, which is the way I do it now. The first time I put a pinion on a Himaxx I did the heat and tap method, had to order another motor due to a slightly bent motor shaft (Will still work in a foamy though! ) And I spent $12 fot a pinion puller to simplify that end of the process also
Have you seen any vids of a zoom running with this motor? I'm curious if an outrunner sounds much difference and if it affects the flying much.
Sar is offline        Reply With Quote
Old 08-05-2004, 08:12 AM   #3
WillJames
Registered User
I should be able to test fly it (3YO Permitting) sometime later today.
William James
