| Spartan RC Spartan RC - Quark, DS760 Gyros and other Spartan RC Electronics Factory Support |
Hi guys, I flew my 500 with the quark on it fine a few hours ago, then I charged the battery, turned the swash mix to -75 for aile and elev (before it was -70), and I turned the gain up to 63% (it was 60% before, I am using the dx6i) I fixed the helis tracking a bit more, so now its spot on, but I noticed that the tail slider, when the heli is on the ground was slowly but surely drifting tot he right, I spooled her up and it took its time before the gyro realised the heli was slowly drifting to the left and fixed it, I lifted it up, and it was wagging, so I dropped the gain back to 60%, the wagging went away, but th slidr was still drifting to the right! also, when I do piros, the tail will bounce back, is there a way to fix these 2 problems? or do I Need to wait for the firmware to come out?
Thanks alot guys.
Trex 500: Spartan Quark+ DS520, 2650mah 30c 6s, DS510's, 500M motor, stock 60a esc, Curtsi Youngblood RAdix 430mm main blades, KBDD tail blades. Messerschmitt 109: all stock, 1800mah 3s 30c lipo. |
btw: theres some bad ish vibes happining on the tail boom support strut and the fins, but I am going to try and cover that in the 500 section.
Hi Incellusion,
i have the same problem as you when i give a sudden right rudder stick it bounce but when i give a left stick it is normal, my Gain is 62% Last night i installed a carbon fiber tail blade and it helps a little, but i think that the Quark can be tweaked to be SUPER by the Flash link, now i feel as if it is a very normal gyro Last edited by kefou; 04-13-2010 at 06:31 AM.. |
The Capi - HF Support
Kefou did you make sure to add roughly 8 degrees of tail pitch for the tail servo center ? Having a bounce on one side and not the other is a sign its not symmetrical.
The Quark cannot be programmed by the FLASH USB link without the SLX adapter, it has not yet come out, but will soon.
SAB Heli Canada / RotorQuest/Compass Team KBDD Spreading capibara awareness since 2006 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Same here, mine will not bounce with left input only right.
#6 |
HFG, when i center the slider the tail is almost 8% pitch,, here is a photo
#7 |
Looks good. What HS you running ?
#8 |
what HS?? tail servo?? i am running s9257
#9 |
HS = Head speed. Many so called gyro problems are actually HS related.
#10 |
really i don't know but i am running a high head speed, my curves is
T 00-60-70-80-90 P 40-45-50-75-100 |
#11 |
it is around 2800 rpm
#12 |
So, is this head speed is the reason or what??
#13 |
I have not discovered the bounce back issue, but I fixed the drifting issue. Rookie mistake lol, I must have plugged in the lipo when the heli was on a bad angle or something, but when I plugged it in again, it armed succesfully.
#14 |
Kefou i suggest learning to fly in idle up, the tail cannot perform its best when the HS is constantly changing.
#15 |
i am already flyin in idle-up some times, and i have tested it in idle up with the same problem.. do you think this problem can't be solved without the Flash link?? or i can fix it mechanically??
#16 | |
These aren't idle up curves.
#17 |
I don't believe its a gyro problem. Your HS is alittle low or at the very least inconsistent. You can prolly mask the problem by adjusting the parameters of the Quark (when the SLX comes out) but i would prefer to solve the actual problem.
#18 | |
electric helis should have very little if any vibes. if it's vibrating bad enough to move that as your describing then you have an issue there you need to address. vibration causes drift and also effects how well the gyro stops because it is buzzing. fix that and see how good/bad the tail is then would be the best advice i think. cheers |
#19 | ||
T: 100-92.5-85-92.5-100 P: 0-25-50-72-100 Quote:
#20 |
A smal info that may help, the bouncing problem were not exsit before my last little crash, i have crashed a little crash that need to replace the main shaft, feather shaft and one servo and the flybar.. and before this crash my tail was rock solid and the gain was 65%.. so the recent bouncing problem is after this crash... also i have changed every thing for testing (Tail boom, tail shaft, tail blades, tail slider, main blades, main gear, tail gear) with no difference.
Can it be the gyro itself?? |
