Old 10-26-2006, 06:55 AM   #1
Taipan
Default Do I need to put grease on the spindle??
It passed through the dampeners easily without grease so no need for it?
Taipan is offline        Reply With Quote
Old 10-26-2006, 07:01 AM   #2
gordohigh
Yes, you should use the grease they supply with the kit as per instructions. This will allow the rubber rings to move more freely without over wearing them. It also allows for a more even movement inside the head dampening......
gordohigh is offline        Reply With Quote
Old 10-26-2006, 11:08 AM   #3
Skiddz
If it moves, lube it. If it's not supposed to move, LocTite or CA it.
-Kevin
Skiddz is online now        Reply With Quote
Old 10-26-2006, 11:21 AM   #4
zflarez
But does the spindle move. If the grips are tight than there should be no side to side movement and any radial movement is all done in the grips. I oil them but just love to argue, so were is the movement.
Raptor 60
Evo 50
Trex 600
Raptor 30
zflarez is offline        Reply With Quote
Old 10-26-2006, 02:49 PM   #5
Skiddz
*IF* the spindle was locked in a bearing or some machined/cast plastic/metal part, it wouldn't move. It does provide some flapping movement via the rubber dampers and should be lubed.
My $0.02
-Kevin
Old 10-26-2006, 04:21 PM   #6
stevehonn
If you don't grease the spindle on a Raptor 50 you get the head nodding, it's supposed to move, all be it only slightly so grease it.
Steve H
Trex 600N Sport, 700N , Trex 250, Beam E4, Trex 550E, Raptor E550, Mikado Logo 500 3D, now a happy user of Futaba 10CG
stevehonn is offline        Reply With Quote
Old 10-26-2006, 06:49 PM   #7
Russ McC
I will not say greasing is the wrong thing to do but I don’t grease them, I come from Min Air and they stress not to grease there’s. I have greased others in the past and never liked it, greasing makes the damping softer, I prefer stiffer, after 200+ flights still stiff and doing great. It does say to grease it and that’s ok but it is not the only way depending on what you are looking for. I am using the black dampers.
Russ McCutcheon
DeeTee Pilot
Futaba Pilot
Russ McC is offline        Reply With Quote
