Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 04-20-2010, 05:55 PM   #1
jaycob
Default S613 Sullivan 6mm Heli Starter Extension - soft tip?
I purchased a S613 Sullivan 6mm Heli Starter Extension and the tip rounded out in just a few starts.... it was embarrassing, I had to put the heli on the ground and stand on the landing gear to remove the starter as it jammed in the starter coupling.
I even order 2 more shafts from Sullivan and another one failed....
I noticed that the tip my not be hardened as it is chromed like the shaft.
Anyone else find that this starter tip failed?
Jason
jaycob is offline        Reply With Quote
Old 04-20-2010, 10:45 PM   #2
jaycob
Default Pictures up
Pictures
ID:	152367   Click image for larger version
Old 04-20-2010, 11:06 PM   #3
helis101
I have had the same problem the tip is wearing out quick and getting stuck in the starter coupling. Its ridiculous what we pay for this starter extension and this happens.
Are you saying you ordered just the shaft and not the whole assembley and how much did you pay for it i didnt no you could do that.
Jeff - Microbeast/Ikon , Logo 550SX ,Protos 500 , Protos 700 V2
helis101 is offline        Reply With Quote
Old 04-20-2010, 11:18 PM   #4
jaycob
Default New extension
I ordered the whole starter shaft and oneway, stripped that shaft, then contacted Sullivan, ordered 2 shafts and paid $18.00/shaft plus shipping (part number is S981711613C) and stripped one and have one left.
I could not find any hobby store or online store which stocks just the shaft.
Old 01-03-2011, 06:43 AM   #5
im4711
Similar issue here. I stripped 2 shafts by now. Packing one of them today and will ship them back to Sullivan to ask fo a replacement. For the amount of money I would expect a bit better quality.
im4711 is offline        Reply With Quote
Old 10-02-2015, 06:54 PM   #6
msallua
Hi, Has been solved the problem of the shaft ?
Align 800e PRO DFC // Align 700N DFC, 105HZ-R HV // Goblin 700Comp // Goblin 420 // Align 700E DFC HV.// Futaba 14Sgh - RealFlight 7.5 // neXt - Powered by Pulse - IKON's // Castle ESC's
msallua is online now        Reply With Quote
Old 10-21-2015, 10:32 AM   #7
LoveToFly1
mine have lasted for years
Gasser Mike
Team Synergy, Team KDE Direct, Rail Blades, TRM Power, Byron Fuels, MKS Servos
LoveToFly1 is offline        Reply With Quote
Old 10-22-2015, 11:33 AM   #8
ticedoff8
I bought one about 3 years ago.
The one-way-bearing failed after the 3rd start.
It looked like all the chrome stripped off the shaft and it could no longer engage with the OWB.
The LHS said "Send it back to Sullivan".
I threw it in the trash.
ticedoff8 is online now        Reply With Quote
Old 10-22-2015, 04:46 PM   #9
rcflier1
bought mine new this spring. 3 heli's 2, 50's and a 91, 5 gallons of fuel. shaft is still fine.
rcflier1 is offline        Reply With Quote
Old 10-30-2015, 06:06 AM   #10
busterboy
I bought a brand new Sullivan same as described here.
Lasted probably 20 flights using a 4s pack on a Dynatron before it rounded the end off and stuck in the coupling.
No replacements around in the uk so the wand is a door stop now.
Really poor how they charge top dollar for poor quality like this.
700KSE
700 Black Nitro
570 SAB Goblin
busterboy is online now        Reply With Quote
Old 11-01-2015, 10:22 AM   #11
malc1
I just emailed Sullivan and sent over a photo of the damaged tip and they sent me out a replacement.
Arrived a couple of days ago and all now sorted.
---- Minicopter Diabolo Pyro750-56 Kosmik200 Vbar v5.3 ----- T Rex 700N DFC OS105HZR Spirit FBL ----- MinAir Furion6 CGY750 KDE600XF G3 ------- RJX Vector 700 Pyro750-56 Comp Kosmik 200 -----T Rex 600N DFC YS60 Vbar v5.3 ----- MinAir Spectra `G` ---
malc1 is offline        Reply With Quote
Old 11-02-2015, 05:56 AM   #12
busterboy
Just done the same Malc after reading your post here.
Fingers crossed I get a result.
700KSE
700 Black Nitro
570 SAB Goblin
Old 11-02-2015, 08:01 AM   #13
malc1
Good luck with it.
Any problems give them a ring.They are very helpful.
