| 450 PRO Class Electric Helicopters 450 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
#41 |
no, i am in avcs
i'm not no newbie ehehe and however with 65% in the gyro menu, the behavior is the same maybe a 13T pignon is little for hard collective manouvers, i just ordered a 14T
T-Rex 450 Pro - Blade mCPX - Blade mSR - E-flite Sbach 342 Parkzone Sukhoi 26Xp |
#42 | |
I still wonder if you have enough headspeed. The TT does actually have a little bit of a lower tail ratio than the belt tails. This is to allow for more headspeed. So a 13T may not be getting enough tailspeed? Does your motor bog when doing collective? 25C batts aren't enough.
Trex 450 Pro 3xDS410M + MKS8910A+, Align FBL head w/Microbeast, CC 45 Gov@ 3400rpm(max timing, outrunner mode), Scorpion 2221-8 on 14t, Edge FBL main and tail, CF boom, CC BEC @ 6V |
#43 |
in your opinion, if the mechanic is perfect in all aspect as i'm trying to do replacing all incognite parts
this issue can be caused only by headspeed, or it is an elettronic issue?? i don't know my RPM, i don't have a tachometer, but 25C are not enough?? maybe the 13T is not enough the motor doesn't bog in full collective are you sure that a flat curve is better then a V one?? if there is a headspeed problem, where tail lose authority, a V curve can keep the Rpm costant when i increase collective for example with 100% flat curve 3200 rpm at center stick when i increase they become 3000 if i set 2800 rpm (90% curve) to center and i increase collective they should become 3000, for pitch and torque they stay at 2800 it is only an example, maybe don't concern my problem
#44 | |
The other scenario is if you use a throttle curve that creates a lot of torque when you apply collective the tail will also want to move over to the right. The steeper the throttle curve the more this effect. Another thing to consider is that with a low headspeed more of the rotation gets made into torque instead of lift. As you use a higher headspeed the blades get better at making lift and make less torque. So the best thing for the tail is to have a higher headspeed and to have the headspeed stay nice and steady. This is why many people like to use a 14T with a flat 100% throttle curve. The other option is to use governor mode(it is complicated to set up and the stock brand isn't the greatest). Try the 14T and definately try to get a higher C rated battery(it will fly better).
#45 | |
100% throttle curve in idle up is working the best for me now after 5 months fooling around with it.....
"It's not the crash so much as the sudden stop" Alees Rush 750, Compass 7HV, Compass 6HV, TRex450Pro, Blade MCPX, bunch of other junk in boxes |
#46 |
copy and paste from other thread
![]() ![]() well well now i have a new enthusiasm i'm so excited to try I Must win, not heli, your help is fondamental for me thanks
#47 | |
#48 |
I've noticed on pictures of this problemed mismarvel that the tail blades have more pitch with the slider to the left than when the slider moves to the right. That won't fly, at least not correctly. Has Align addressed the issue? If not I'm not buying one! I don't settle for mediocrity and you shouldn't either!!! Time to boycott??? They haven't adjusted their prices in our economic crunch anyway!
E-Flite Blade mCX x2, E-Flite Blade CP PRO, Align T-Rex 450 SE V2 w/ Hi-Tec HS 65HB cyclic servos, JR DS 3500G tail servo, E-Flite RG 90HL gyro, Align RCE-BL35X esc, Align 430X 3550 KV brushless, Spektrum DX6i DSM2 TX, Spektrum AR6200 RX To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#49 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() :w ow2:![]() ![]() ![]() ![]() ![]() ![]() :wow 2:![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by bchrny; 06-02-2012 at 11:31 PM.. |
