Old 04-27-2010, 07:39 PM   #1
Aussie_phoenix
Question Good cyclic servos for 450 3G
OK - finally been burned by my Align 410Ms. After a light crash with my 3G system stripped gears on all 3 cyclics and when replacing gears found that the motor (or whatever the correct technical term is) had busted loose in one of them. Coupled with this the aparrent 30% premature failure rate of these servos I'm looking to put something different on my 3G system. Don't really want to go with Hitec HS5065s as they are a bit slow at 0.11 sec when the 3G manual specifies less than 0.09 sec.
Any ideas on other digital servos that run under 0.09 sec, possibly inolab or MKS.
Trex250 Phoenix25, DS410 GP750 5084 AR6110
Trex450SEV2TT 4S Scorp-8 Phoenix45 CC10 Spektrum H3000 MKS-DS95i AR7200BX
CopterX450ProTT 4S Typhoon2218 Phoenix35 HS65MG GP750 MKS-DS95i AR6100
Trex600E 8S 1910H/1Y HV85 5625MG Gy611 S9256 AR7000
Aussie_phoenix is offline        Reply With Quote
