Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 05-01-2010, 07:41 AM   #1
BLAZE86DUBZ
Default 700 maiden flight today
im going to maiden flight my 700 today to start the break in how should i set my throttle curves? should i keep them 25 50 75 100 for the break in?
BLAZE86DUBZ is offline        Reply With Quote
Old 05-01-2010, 08:45 AM   #2
Z900
Assume without governer ?
Best in idle-up with something like: 70-60-50-60-70
normal something like: 0-35-50-60-70
| mCPX BL@DX6i | Trex700N-LE@BX | TDR@BX || FunJet 2W20@4S | SwiffieII || FF10 || 720i DUO3 | ALC8500
Z900 is offline        Reply With Quote
Old 05-01-2010, 02:17 PM   #3
glen09
seriously are you going to be going much above center stick on your first few flights on a brand new motor?
glen09 is offline        Reply With Quote
Old 05-01-2010, 04:51 PM   #4
outhouse
heck ya lol
you want to heat the motor up some , you dont want it cold it will never break in.
im with 0/25/50/75/100 on a 90 motor.
first flight hover a little rich in normal mode
second flight FF in normal mode
third flight idle 1
4rth flight idle 2
you need to land 2-3 times a flight to check temps and adjust needle. 1rts tank wont need much, 2nd and 3rd tank need it allot as thats when most of the ring seating will take place.
trex 450pro
trex 500 1400/bl60g, 15t, 6s, gp750/9257, 9650mg's,TT
trex 600E 600xl/bl75g, 6s, 10t, 750/9256, hs5625mg's, TT
trex 600N OS50hyp, hitori, mgp, 9451'sgy520/9256, TT
trex 700N 91sz, hitori, g600, 610's, 611/9256, TT
outhouse is offline        Reply With Quote
Old 05-01-2010, 08:45 PM   #5
davidz58
I maidened mine today, but unsuccessfully.
Motor wasn't running right at all, until I discovered there is a hole that I did not put the plug in on my Outrage pipe..... drove 1 hour to the field. had all my tools, except for that plug... bummer....
but my friend's 600 3g maidened perfectly. nice power even on 15% nitro on the OS55 motor.
- Trex 700 LE (Spartan Quark, Multigov Pro, 91H + Outrage); JR9503 & DX7
- Trex 600 Nitro Pro (Futaba 611, Mutligov, Align 55 + Outrage)
- Trex 450 Pro (GP 750)
- 2 * Trex 250 Pro (GP 750)
- Walkera CB100/4#3a/4#3b/4#3b DB/5G6
davidz58 is offline        Reply With Quote
Old 05-01-2010, 09:28 PM   #6
BLAZE86DUBZ
never made it today had to many things to do question though im using the gryo menue on the dx7 for the governer how do i turn it off for the first few flights?untill i break it in?
Old 05-02-2010, 03:25 AM   #7
face992
Lol yes read the manual^^ this thing is kinda important...
I broke in my motor with gov on, no problem with that. You just need to keep an eye on temperature and smoke and you need to listen to the motor. I just varied in rpm, Bert and Bobby do it the same way, just with gov on (see smacktalkrc). My motor is running pretty good now...
face992 is offline        Reply With Quote
