Go Back   HeliFreak > R/C Electronics Support > Electric Motors, Gearing, Speed Controls, Gyros, Receivers, and Other Electronics Discussion
Electric Motors, Gearing, Speed Controls, Gyros, Receivers, and Other Electronics Discussion Electric Motors, Gearing, Speed Controls, Gyros, Receivers and Other Electronics Discussion
Old 05-02-2010, 11:07 AM   #1
jw637362
Default Govenor Magnets / Installation
I replaced the plastic fan with an Aluminum upgrade on my Raptor. When I installed my Magnets. I in-advertantly installed them both Positive side Down toward sensor.
I know that Some Governors, throttle jockeys etc need to have 1 positive polarity down and 1 neg polarity down so it does not read them both and thrash the settings.
I have the Futaba GV-1 and when I rotate it, I am getting Sensor reading on the pickup magnet of 97% and then the other comes around and it only registers 4 - 5%. I believe this govenor is only reading the one magnet but the book states to mount the opposite balancer magnet with opposite polarity.
Should I need to dismantle this thing and drill it out to put in opposite way.
Thank you[8|]
Electrics - Hummingbird V2: Helimax MX-400: EXI 450:
Nitros - Raptor 50 Titan SE: X-Cell 60 Graphite SE
jw637362 is offline        Reply With Quote
Old 05-02-2010, 11:10 AM   #2
howardm4
well, something isn't quite right because the GV1 sensor is only sensitive to 1 magnetic pole.
so, if you really put them in the same side 'up', then it should read 97% or so for both. If it's only reading 4-5%, then you should be OK.
howardm4 is offline        Reply With Quote
