| Airplane Related R/C Airplanes Discussion |
i have a 430L BL motor 3550 KV it came with my trex sa. i was wondering if i could usse it in an airplane. if i can what size prop ? the esc is a 35a BL thanks
For practical purposes and in general Id have to say NO.You can roughly figure a 3550kv motor on 12volt is going to turn 40,000rpm and then some.Even with a good load on it I think 30,000 easily.I think I saw a thread somewhere of someone doing it but you would need a tiny prop like 3x3 or something like that.Like a ducted fan without the duct.
Thats my thinking on it.Maybe someone else has another idea.
Too many helis & Too many planks Lots of DX radios & A couple Futaba radios AMA member & Full scale plank driver HELIFREAK !!! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Gear it and turn a big prop.... Kv is definitely too high to use that motor in a propped airplane unless it's geared and run on 2 cells. Ducted Fan use might be ok tho..
-Kevin No helicopters were harmed in the creation of this post. AMA CD # 7309, Turbine Waiver# RW 890 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
A couple guys have good success with an APC 4.1x4.1 on a wing.
How much past 200 mph do I need to go you ask? |
maybe as a pusher with a 4" prop, anything else ain't going to cut it. Motors are so cheap these days just get something more appropriate, I'm currently swapping my blown 2900kv motor plus 3:1 gearbox for a 1000kv unit for about £12
