Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 05-04-2010, 03:20 PM   #1
Jotto
Default Onboard temperature gauge
I would like to know the maximum temperature on my engine during flight, as the temperature quickly gets lower after I land.
Is anyone using an onboard temperature gauge that can show the maximum temperature, like this: http://www.greathobbies.com/producti...rod_id=TRX4091 ? Is it worth investing in?
Jotto is offline        Reply With Quote
Old 05-04-2010, 03:38 PM   #2
face992
Yes I'm using sth like this on my heli too. Its really worth its money since you can see the max temps while doing tic-tocs e.g., very important for engine tuning...
face992 is offline        Reply With Quote
Old 05-04-2010, 03:41 PM   #3
Jotto
Cool (pun not intended) :-)
Are you using the Traxxas gauge or another device?
Old 05-04-2010, 03:50 PM   #4
face992
No I'm using this one since I'm living in germany: http://www.freakware.de/shop/artikel..._artikel=16238
But I thinks its pretty much the same... your one is cheaper^^
Old 05-05-2010, 02:40 AM   #5
chosen69
That's what I'm using. It works great !
http://www3.towerhobbies.com/cgi-bin...&I=LXGZK7&P=ML
Trex 600EFLpro
Trex 600NSP DFC
Trex 700E DFC
Goblin 700
chosen69 is offline        Reply With Quote
Old 05-05-2010, 05:26 PM   #6
Fluidtech
Red face
This is what i use.
http://www3.towerhobbies.com/cgi-bin...?&I=LXEMG5&P=M
still have to wait for the main blades to slow down a bit before i lean over and slow the head button down' unfortunate part is i get inacurate info as its had seconds to cool before getting my reading.
those on board ones are proberbly the way to go.
Fluidtech is offline        Reply With Quote
Old 05-06-2010, 11:29 AM   #7
BlackWatch88
The Multigov Pro does it, just plug in the display and it will tell you the max temp reached in the flight. You do need to get the temp sensor mounted
BlackWatch88 is offline        Reply With Quote
