Old 05-06-2010, 04:19 PM   #1
HeliBenj
Default Gryphon auto booster glow ignitor
So I'm switching to FBL and decided to go from align 2in1 reg to a separate higher rated reg. I chose the ElyQ as I got one for a very good price.
As I'm losing the 2in1 glow function, I'm giving this device a try:
http://www.gryphon-mall.com/product.php?id_product=24
Basically like a switchglo but half the price on ebay. I just couldn't spend the $ on a switchglo which seems a bit overpriced to me for such simple a device.
Has someone tried one of those yet?
I'll let you know how it goes when I get it (2-3 weeks )
Ben
Goblin 500 IKON w/ gov, Quantum 4115-1200, Hitec 5245, BLS251
DX8, RF6
HeliBenj is offline        Reply With Quote
Old 05-06-2010, 05:14 PM   #2
Fluidtech
Talking
yeah i looked at those
please post your thoughts once you get it in.
Fluidtech is offline        Reply With Quote
Old 05-09-2010, 11:06 PM   #3
Gryphon
Default Gryphon AUTO Booster
I appreciate for your interest.
If you wonder anything about the Auto Booster
or need help , don't hesitate to contact us.
Thank you.
Gryphon is offline        Reply With Quote
Old 05-10-2010, 01:33 AM   #4
johanngj
Hi, can the built-in buzzer be disabled? Or will it make a noise as long as it is heating the plug?
________________________________________
TREX 600 T-BAR, RJX FBL head, Align 55, FunTech A170 BLS451x3, BLS251, GV1, Arizona, Quick UK swash, Fusuno v2,
johanngj is offline        Reply With Quote
Old 05-10-2010, 11:26 AM   #5
HeliBenj
Thank you.
Good you're here!
I didn't understand the manual fully: the part about the jumper. Do you have to match the voltage of your receiver? For instance if my receiver is powered at 5 volts, I put the jumper in the 4.8 plug?
Ben
DX8, RF6
Old 05-10-2010, 10:10 PM   #6
Gryphon
it is made to work automatically while heating plug.
if you don't want buzzer, i can send you after removed.
thanks!
Old 05-11-2010, 01:31 AM   #7
Gryphon
You are understanding well. You can put the jumper in a booster which has the closest voltage to the receiver voltage.
When the red-heat intensity of a plug is set to be weaker than the
basic setting value, please insert after moving a jumper connector to
be lower than its own voltage connector.
Old 05-11-2010, 11:48 AM   #8
HeliBenj
I hope I receive it soon and I will report back when testing it.
Ben
DX8, RF6
Old 07-21-2010, 11:28 PM   #9
francowong7828
hi gryphon,
i am having a question about the jumper within the auto booster. knowing that align 2in1 regulator voltage is 5.8V, where should i place the jumper in the auto booster? in the 6V slot? on the other hand; if i am using a duralite 7.4V regulator, the the jumper within the auto booster should then be slot into the 7.4V socket?
kindly advise.
TREX700FBL - OS91HZ; CYMP6; FUTABA CGY-750; FUTABA BLS251
TREX700FBL- OS91HZ-R; HATORI; TOTAL-G; FUTABA BLS251; ENV90- YS91-3DS; HATORI; TOTAL-G; FUTABA BLS251.
francowong7828 is offline        Reply With Quote
