Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters > Cypher 3D
Cypher 3D EF Cypher 3D
Old 05-08-2010, 11:09 AM   #1
kevinbattista
Default CYPHER HEAD SET UP~LINKAGE meassurements
When setting up your head adjust the links as needed so that:
-Servo arms are horizontal
-Swash plate is level
-Washout mixer arms are level
-Fly bar arms are level
-Main blades have zero degrees pitch
This should be done when both sticks are centered on your radio and with your pitch curve setup for zero degrees at mid stick.
The above will give you push rod lengths of:
-Blade grips to fly bar mixing arms = 18mm
-Fly bar mixing arms to swash plate = 40mm
-Fly bar arms to washout mixer arms = 24mm
-Swash plate to front-left and front-right servo arms = 33mm
-Swash plate to rear servo arm = 29mm
There is a photo of the Cypher's head at zero degrees on page 3 of this PDF:
http://rcheliguy.com/global/airtroni...elicopters.pdf
it's not a competition, it's a hobby
EXI 450 + FUTABA t7c Tx =
Phoenix Sim "it's free to crash on a sim"
kevinbattista is offline        Reply With Quote
