Old 05-08-2010, 10:10 PM   #1
ochants76
Default What is causing the tail to do this?
When it spools up the tail starts to wag to the left. It seems to be kind of a notchy type of wag. It seems to wag a few inches and then it quickly stops as you can see from the video. It does it with no rudder inputs. I have also noticed that as soon as I hit the throttle hold the tail blades stop immediately and the mains slowly spool down like normal. I made sure there is no twist in the belt. The gyro is a 401...not sure if it is a gyro problem or not.
ochants76 is offline        Reply With Quote
Old 05-09-2010, 01:33 AM   #2
Mr dan
Watching the video I can hear the tail fins" hunting" thats the "whap whap whap" sound and the jitter you see and hear. what cause's this is the gain on the gyro is too high. What kind of Tx do you have? You need to set the tail gyro up in rate mode 1st then HH. while your tail is hunting lower the gain setting in the Tx if your radio allows it.
Mr dan is offline        Reply With Quote
Old 05-09-2010, 01:35 AM   #3
sethf8403
is your gyro maybe reversed or something?
sethf8403 is offline        Reply With Quote
Old 05-09-2010, 01:46 AM   #4
makmov
I would say something is reversed, the rate mode set is way off, or you have your gyro set up on the wrong channel which is easy to do.
makmov is offline        Reply With Quote
Old 05-09-2010, 01:46 AM   #5
wannaflyguy
It could be a combination of both... a reversed gyro with too much gain. I'd also recommend that you check to make sure that your rudder ATV is at 100%. You'd also need to check your gain in your flight modes as well-- N, 1, 2.
RC Heli's are flying moneypits!
wannaflyguy is offline        Reply With Quote
Old 05-09-2010, 12:37 PM   #6
vertualex
I have same exact issue with my 250 SE. I had originally JR 370 and now changed it to Quark. Same problem. Tail feels a little too sloppy when moving blades by hand. My Tx is X9303 and tail servo Ino-lab 201. Thanks.
vertualex is offline        Reply With Quote
Old 05-09-2010, 12:56 PM   #7
makmov
Make sure your tail is going the right way. It's easy to get the belt on so the tail rotors are going backwards.
Make sure you have your Gyro on the right channel and you are programming the channel the gyro is on.
Make sure you have a good no trim rate mode tail.
Make sure the gyro is not reveresed.
Make sure you don't have too much gain in HH.
Old 05-09-2010, 07:26 PM   #8
ochants76
It does it no matter if it is in hh or rate mode and changing the % makes no difference. It corrects the right way when I move the heli left or right. Blades are spinning the right way also. I am using the correct channel for the gyro(light goes off when I switch to rate mode). Tx is aurora 9 and tail servo is inolab. It almost seems like it could be mechanical since changing the gain has no affect on it however if I spool up without blades it doesn't wag.
Old 05-09-2010, 08:19 PM   #9
fireplug1111
Try taking off from the floor and not the wall. That might help!
WHEN THE ENGINES QUIT,,,,, GRAVITY REALLY SUCKS....
UH-1D HUEY CREWCHIEF "83 to 94" "RANGERS LEAD THE WAY"
fireplug1111 is offline        Reply With Quote
Old 05-09-2010, 08:52 PM   #10
vertualex
I was checking my channel assignments and in 9303 gyro is supposed to be on Aux2 but in my receiver (6110) it plugs into Gear. so gyro is controled by Aux2 not by gear channel. How can I remap it?
Old 05-09-2010, 09:50 PM   #11
No_Gassers_Here
I have the same box you do the mapping in the model set up. trun your box off. press and hold down the roller and turn your radio on select the model. after that you will have the switch opt. put the gear on gear. set your travel for the gear on +24 and the off to -24 to start. mine runs +26 and it holds to even the hardest punches. but it will very from heli to heli. hope this helps.
The ground is only one dumb thumb away!!!
Trex 600CF Silver,401/9253,60XL/75amp,all the metal bling bling
250v1 410's(5065mg's when I get a minute),750g,5084mg, hyperion battery( currently my favorite heli)
450SE V2 NUE 1107/2/H/2.3, CC45apm esc,770 3D/3400g,65mg,V_Blades,4s 21ooma Hyperions
No_Gassers_Here is offline        Reply With Quote
Old 05-09-2010, 09:54 PM   #12
ochants76
hah I don't know why it looks that way on youtube. When I watch the video on my phone or quicktime it is the right way.
Old 05-09-2010, 09:57 PM   #13
Inverse
Do you have the weighted SE tail on it?
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Atom 500
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote
Old 05-10-2010, 12:29 AM   #14
makmov
Just plug into AUX2 like it should be.
You can use gear... I think on that radio but it's just harder to set up because the lables are all different.
Old 05-10-2010, 12:31 AM   #15
makmov
Seems like the gyro is reversed then, which is different than the servo direction.
Old 05-10-2010, 12:43 AM   #16
No_Gassers_Here
he is running a 6 chan rx. I have mine set up throw the gear switch. old school. the x9303 will not let you use the gyro gain control on a 6 ch. so youhave to go old school dx6 style. the way finless showed us in back in the days.lol
Old 05-10-2010, 12:47 AM   #17
No_Gassers_Here
when you set the heli up this way. with the x9303 the head holding starts at 0(or 50 on gain) so +24 would = =74 on hh and -23 would be -27. 50 being where hh starts and 0=50 hope this helps...
Old 05-10-2010, 06:11 AM   #18
vertualex
Yes, that seems to be a problem. When using gear switch it goes to HH and rate mode but in Travel Adjust it is +100% and -100% so the gain is through the roof. I changed it to +24% and -24%. I will test it later on today but seems like a definite issue. Thanks for help guys. BTW there is some info on JR forum on how to set it up for different flight modes through mixing.
Old 05-10-2010, 08:41 AM   #19
makmov
Yes, my JR652 was like that also.
Old 05-10-2010, 04:55 PM   #20
No_Gassers_Here
yes you can use the gov. instead so it is controlable in all 6 flight mods but I find that with the little 250 I really don't know all the fancy setings. it's on rails now can't see changing it. also I have always trusted what I learned for finless. if it ain't broke fly it. If Bob (finless) has any changes he is doing now I wish for him to give me the heads up. but with this 250 I feel I have mine perfect. and seeing as Finless doesn't really care for the 250's( to small for his freaking huge hands.lol KJ) i think I am going to leave it the way it is.
Vert. please let me know when you test it and tell me if that fixed you up. also I got a few more tricks for the X9303 if your interested hit me up on the p.m. and I'll toss you up a few great tricks we can do with this TX. I love mine kinda digging the X11 now to. cant wait for that to hit my front door.
