Old 05-09-2010, 12:47 PM   #1
burton8012
Default SwitchGlow install on a Skookum 720 and DX7
whats the best way to hook up a SG? theres high and low voltage ports on the power buss so im wondering can i hook it up the same way like a ar7100r? just use a spare port on the low voltage side and then set up my program mixes?
burton8012 is offline        Reply With Quote
Old 05-09-2010, 10:55 PM   #2
burton8012
anyone??
Old 05-10-2010, 01:00 AM   #3
Skint Eastwood
Well firstly I have to confess that I am an 'Electric' only pilot, but I took a look at the website and it appears to me that you connect it as follows
If you have a spare channel on your Rx then just plug in and connect to engine.
If no spare channel then just 'Y' it in and coinnect to engine and use optional 'pushbutton'
Edit. it doesnt need to be connected to the bus at all just the RX so just use as you normally do.
Do not forget that the 'Bus' is just that, it does not inherently have a lo and hi voltage side, it is just seperated so you can supply it with two voltages of your choice. It has no logic or circuitry, it just routes the pins to different pins on the 4 Bus connections
Skint Eastwood is offline        Reply With Quote
Old 05-10-2010, 06:07 AM   #4
burton8012
looks like i can only use the power buss to plug anything is cause i used the power buss i can no longer plug anything right in directly into the skookum 720...so maybe i can just yuo a Y harness like you said but for the TAIL port on the power buss and just set it up if i had a switch for rate mode....or maybe i can just use the spare low voltage TAIL port and do the same thing but without the Y harness
hmmmmmm
Old 05-10-2010, 08:23 PM   #5
panzlflyer
If your using a seperate reciever then you would hook the device to the reciever, if your using the 720 and sats then you have up to 9 channels/limited by your radio in your case to 7
Trex 700n, Vbar ,12z,10x, HtFpv, Dji Naza Fw550, Dragonlink.
panzlflyer is offline        Reply With Quote
Old 05-10-2010, 09:06 PM   #6
burton8012
the thing is theres no GAIN channel on the power buss thats how i would hook it up on a regular RX can';t seem to find what will work
Old 05-11-2010, 06:07 AM   #7
panzlflyer
The ones labled IO, then play with your switches, end points on the channel chosen, theres a couple of other posts on the subject of setting up the unit for aux1 etc
