Old 05-10-2010, 11:49 AM   #1
boriqua935
Default Problem with Align 35a
Hi just but in an Align 35a esc. Problem is that I programmed it and it seems to jump up in head speed around 3/4 throttle causing heli to pop up. How doe you guys have yours programmed?
Trex 450 se V2, Hitec 65mg, Futaba 401 and 9257, CC 35a esc
Trex 600 to many mods to list
boriqua935 is offline        Reply With Quote
Old 05-10-2010, 01:38 PM   #2
whoanelly
Dont have that ESC but did you set your throttle end points?
700LE : 105HZR AR7200BX JR8917 Multi gov , JR9503
600ESP : 100AMP Castle. Scorpion Motor . AMA #962896
400 Blade : Scorpion 2221-6 ,Castle ICE 50 Sonix Head and t
Align 450 pro V2 3G MKS DS95 MSR , 2 x MCPX (brushless C05 & HP05), Blade 130X.
whoanelly is offline        Reply With Quote
Old 05-10-2010, 01:55 PM   #3
boriqua935
got it figured out. I needed to change thortle response from fast to slow.
Old 05-11-2010, 02:46 PM   #4
1BADAIR
just about everyone uses fast response on heli's
Compass 7HVU HBL980/950 Ar7200bx Edge160-- Compass 6HV, 610/650
TRex 700LE , Beastx 610/650, Warp360 TracX 92A+
1BADAIR is offline        Reply With Quote
Old 05-11-2010, 03:18 PM   #5
scott s
Are you in governer mode?? That could cause it. The governer is usless on the align
scott s is offline        Reply With Quote
Old 05-11-2010, 10:50 PM   #6
boriqua935
No not in governor. Gonna correct the sonix tail first then take it from there
Old 05-12-2010, 10:12 AM   #7
1BADAIR
what are your throttle curves?
Old 05-12-2010, 10:45 AM   #8
boriqua935
linear in normal and idle up
Old 05-16-2010, 04:15 PM   #9
CoolKD
Got the Align 35A G ESC and I'm using the stock settings. I always fly in idleUP 100% so havent notised this.
Glad you got it sorted. Wery nice ESC BTW
It runs nice and cool with the stock motor and 25C pacs
Blade MSR, MCPX v2 & 400 3D NightRig
Align Trex450 pro.
Align Trex700LE N.
SAB Goblin 700Comp.
CoolKD is offline        Reply With Quote
