Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > Outrage Velocity 50 Nitro
Outrage Velocity 50 Nitro Outrage Velocity 50 Nitro Helicopter Factory Support Forum
Old 05-14-2010, 08:22 AM   #1
visionplay
Default Sab 620 Red Devils wont fold back
I just put on the new 620mm Sab red devils on the V50 and they wont fold back into the blade holder
They only turn about 30 degrees and then hit the spindle bolt and wont go any further.
Anyone else tried these? Is it safe to dremmel the Carbon on the edges to give it clearance so they can turn in the grips? (i would not think so)
John
Logo 600, Vbar, Jive 80HV, Pyro 700, BLS.
Synergy N5, OS55, Vbar
Mini Protos FBL, Vbar, YGE, 3S TP 65c's.
visionplay is offline        Reply With Quote
Old 05-14-2010, 12:39 PM   #2
Eric Brandenburg
Yes, you can dremel or file down the corners of the roots on these blades to get them to fold. Just be careful to only take off what is needed, if you go too far there is a possibility of weakening the blades.
Give me a lever long enough and I'll move the world...
Eric Brandenburg is offline        Reply With Quote
Old 05-14-2010, 03:44 PM   #3
acri84
I had the same problem . U can take your spindle bolts off and replace washers with MisAlign spindle washers. Problem solved.
Mike
acri84 is offline        Reply With Quote
Old 05-14-2010, 05:28 PM   #4
highland flyer
The UK SAB importer gave the OK to remove enough to get the blades to fold as the roots are solid.
highland flyer is offline        Reply With Quote
Old 05-15-2010, 02:40 AM   #5
visionplay
Sweet, Thanks for all the replies!
John
Old 11-23-2010, 11:38 PM   #6
reaziel
i have the 600mm same problem i seen this and it worked
thanks for the tip
reaziel is offline        Reply With Quote
