Old 01-06-2017, 07:38 PM   #501
TRex700MRX
I have spent the majority of this "bad weather" day reading this complete post.
"Very Informative"
QUESTION: What is the main feature everyone loves the most with this unit?
Does it have a Return to Home feature?
I am thinking of installing one on my Walker 450. I see several have done so. Any comments on my thought? Pro's - Con's?
Thanks, Dennis
TRex700MRX is offline        Reply With Quote
Old 01-06-2017, 08:31 PM   #502
CZorzella
"Very Informative"
Thanks, Dennis
Dennis, the co-pilot is still a viable self level system, it does need to be used with an external receiver and having it installed with the hard deck add-on, it's where the co-pilot shines.
Cons: The static pressure tube hanging from the tailboon is cumbersome and ugly. I wish it could be replaced by other type of sensors. Separated vertical and horizontal optical sensors, the HD and the CPII modules should've been integrated into a single physical unit.
Pros: The hard deck and rescue functions simply works, always! Very easy to setup and use.
Keep in mind that despite of the fact that CP-II really does the job pretty well, there is also FBL controllers that have self level and bailout too now. Perhaps you may also want to consider these options.
I still enjoy flying my trusty 500 with CP-II on it. I always have lots of fun testing complicated maneouvers first above the hard deck, without being afraid or concerned of crashing.
Carlos
CZorzella is online now        Reply With Quote
Old 01-06-2017, 08:37 PM   #503
CZorzella
Default Co-Pilot II - How To, Made Simple!
Here you can find the most complete CPII + Hard Deck combo available.
http://www.store.revolectrix.com/Pro...Co-Pilot-II-C6
Carlos
Old 01-08-2017, 06:42 PM   #504
nightflyr
"Very Informative"
Thanks, Dennis
Main feature is that it works for both helicopter and fixed wing.
It tune-able to your liking.
The hard deck functions quite well for its intended purpose, which is a training tool.
30' (9.1m) minimum hard deck height.
Can be used in series with a FBL controller providing you have a separate Rx.
The only Con, if you can call it that is that you will have more wiring and components to deal with.
