Go Back   HeliFreak > R/C Helicopter Support > Audacity
Audacity Audacity Pantera Helicopters Support
Old 05-22-2010, 10:48 AM   #1
grwarlock
Default .30 sized Pantera Conversion
So, you wanna .30 sized ship do ya ?
Thats not hard at all. The doctor is in the house and has the right tools in his tool bag to help you with the change.
What you need.
1 32-39 2 stroke heli motor of your choice.
1 JR venture 30 motor mount.
(depending on the mounting flange of your motor you can use the stock motor mount. In my case it was a .36 TT pro so I got the venture .30 mount)
1 set 550mm blades.
Now , build the kit to spec's. follow the motor mounting and dial indication as normal.
Setup is the same and can be tweaked after to best suit your motor choice.
Go fly !
Simple huh.
Very stable as it is a Pantera, longer tail means rock solid stay put tail. Smaller engine = better gas mileage.
You can shorten the tail if you like with a jr venture tail boom, tail box and belt but you must also get the idler pulley as the belt has different teeth and will not mesh with the stock on the Pantera.
How many of these are flying atm ... 2 that I know of including a 4 stroke version.
I did not include pictures as there are no real changes just a motor , blade swap.
So we add this one to our "Just shut up and fly" Conversions
Ken
Pantera 50's with the following mods. CRRC 26cc Gas, Saito125 4 stroke, Minime mod's .61 4 stroke, .36 2 stroke Eastern Field Rep. for Audacity Models. www.audacitymodels.com
"The most convertible RC heli in the world"
grwarlock is offline        Reply With Quote
Old 05-22-2010, 06:05 PM   #2
Mr.HillBilly
A Century Hawk 30 motor mount is a direct drop in also.
Mr.HillBilly is offline        Reply With Quote
Old 05-22-2010, 07:08 PM   #3
grwarlock
Thank you for that info HB !
Old 05-26-2010, 11:39 AM   #4
helipainter
My OS32 is mounted on a ergo 32/46 mount and it went straight in. Love the way it flies being so light. Stable and predictable. Doesn't need a whole lot in the way of servos cause there just isn't much forces on em. Am running JR nes-517 and they actually perform.
Guess that makes three lol
US Drones
Aerial Media Pros
Ritewing
Last edited by helipainter; 05-26-2010 at 11:49 AM.. Reason: had to go take a look
helipainter is offline        Reply With Quote
Old 05-26-2010, 05:46 PM   #5
grwarlock
Default Here some pix of mine
36 pro TT for power !
ID:	159056   Click image for larger version
ID:	159057   Click image for larger version
ID:	159058   Click image for larger version
Old 05-26-2010, 09:28 PM   #6
Mr.HillBilly
I have a TT 36 that just loved to start running backwards after you run it for a bit. Took it out and put it on a test stand with a undersided prop to try and blow it up and ever since it has been the best airplane motor I have ever had. I never did try it on a Heli. again tho.
Old 05-28-2010, 08:58 AM   #7
nighthawkron
This probably sounds dumb but I wonder if an OS 48 surpass would have the torque to fly this bird with ?
nighthawkron is offline        Reply With Quote
Old 05-28-2010, 08:06 PM   #8
helihole
Barely!
helihole is offline        Reply With Quote
Old 05-28-2010, 10:50 PM   #9
grwarlock
Uhh 4 stroke, NO.. .61 would be the very smallest I would use and even then its performance is below par. I know I did it. Thats why the build for the 4 stroke is .91-125.
That gave the HP's to pull the blades at a decent speed to fly.
But now 2 stroke I would say .30 all the way to .91 0r larger if you can fit it and gear it.
Can't say to much but I have seen a P50 with 800mm spinning. Was stable and impressive.
Any how I'm derailing this thread as its supposed to be about .30 conversion .
........... back to the .30 discussion.
Old 05-28-2010, 11:08 PM   #10
Ken Here
grwarlock, do you think a .61 4 stroke would be ok for beginner non 3d forward flight? Thanks in advance.
Ken Here is offline        Reply With Quote
Old 05-29-2010, 10:03 PM   #11
grwarlock
If your new to heli's stick with stock. You have a cooling issue to over come and that at this time comes with a price tag of around 80.00 (fan,esc,battery.) for the 4 strokes.
Until one of us can find a fan that works on the stock hub and does the job properly this is the only solution to cooling them.
Ken
Old 05-29-2010, 11:54 PM   #12
redgiki
Having built my Pantera with 3 different engines prior to fitting the winner, I have to say just buy a good .50-sized 2-stroke for your first Pantera. The OS .50 hyper flies it great, it fits perfectly, you have no alignment or other issues, and it just goes. Any other similarly-sized engine should be just fine and work well with the snorkel & fit perfecxtly.
Buy a second kit and build something neat with it once you've built one bog-standard Pantera that flies great
Fly Cheap. Fly Hard. Fly Daily.
redgiki is offline        Reply With Quote
Old 06-03-2010, 05:11 PM   #13
forvols
Location: Resaca Ga - approx 45 miles South of Chattanooga, TN
What you need.
1 set 550mm blades.
Go fly !
Simple huh.
Does the 50 size fan hub work with the OS.32? I never thought about a .32 using the same size crankshaft as a .50.
Lifetime member of the Non-Sheeple Society
Awed by the young men/women serving in the US military
Ashamed of the men/women leading our nation
Saved to the uttermost!!!
forvols is offline        Reply With Quote
Old 06-03-2010, 05:15 PM   #14
grwarlock
I can speak for the TT 36 pro, it works on it !
Ken
Old 06-03-2010, 07:22 PM   #15
helipainter
yes, it bolted right on. Part of the collet sits a little funny on the crank, think part of the crank is machined off but cranked down with the crank lock tool it stayed fine.
US Drones
Aerial Media Pros
Ritewing
Old 06-03-2010, 08:03 PM   #16
forvols
Interesting. Thanks guys!
Old 06-03-2010, 08:16 PM   #17
dharwood
Curious why you are so interested in the .30 conversion?
Its almost as if you know someone with kits AND a .30............
hummmmm,
Dale
all kidding aside, thanks for all of the valuable information!
dharwood is offline        Reply With Quote
Old 06-03-2010, 08:47 PM   #18
forvols
Not to worry dharwood.. Also looking at some interesting WTS's for OS 50 hypers. It's as if I know somebody who is reeeeeeaaally gonna want a 50 pretty quickly.
grwarlock - does the 30 with full P50 boom feel ok in the air? Have you ever flown a Raptor 30 or a Century Hawk 30? If so - how would the P50 full boom compare as a .30 powered heli? Obviously we're talking about hoverability/general flying around with NO aerobatics.
Old 06-03-2010, 09:39 PM   #19
helipainter
I came from an ergo 30, had this motor/mount in it. This thing bar none flies loops around the ergo. The head is so predictable, same as it feels with the 50 in it, just less pop
here is the 32 on the p50 with full p50 boom. It has nes 517 servos in the mid .20's so it has a little corrections going on to keep it still, but you get the idea. IT was one of the first flights i put on it and kept making shots at pulling up on the collective near the ground to make sure something was there.
skip the first minute, i take it over the mulch and hover for a bit to make sure the carb smart i just installed was working, Also the punchout was 11 degrees, i since knocked it back to 9 and it looses much less head speed now. Awesome tame trainer
US Drones
Aerial Media Pros
Ritewing
Old 06-03-2010, 10:01 PM   #20
dharwood
Hummmmmmmmmmmmmmmmm,
forvols, I have a plan..................
Thanks helipainter for the video.
Dale
