Old 05-23-2010, 09:36 PM   #1
pamadren
Default Need help on wiring the Blade 400 back to factory
I had to rebuild my Blade 400, and I made a drawing for the servo connections but must have missed something. Have it back the way it should be but cannot get a response from the system. Can someone please tell me the setup.
Not sure if the reciever could be messed up. Worked before I took it apart.
.... Thank you
Also how can I tell if the elec motor control is bad?
pamadren is offline        Reply With Quote
Old 05-23-2010, 09:40 PM   #2
whoanelly
Thanks to Larry for the link,,,,.i think everything is fine ,,probably need to rebind .
http://www.helifreak.com/album.php?a...ictureid=27623
700LE : 105HZR AR7200BX JR8917 Multi gov , JR9503
600ESP : 100AMP Castle. Scorpion Motor . AMA #962896
400 Blade : Scorpion 2221-6 ,Castle ICE 50 Sonix Head and t
Align 450 pro V2 3G MKS DS95 MSR , 2 x MCPX (brushless C05 & HP05), Blade 130X.
whoanelly is offline        Reply With Quote
Old 05-23-2010, 10:50 PM   #3
Larry227
Ted_wears_a_hat really gets credit for that picture. I was just too lazy to find the old thread in my subscriptions so I linked to the pic in my album.
Trex 700 Pro DFC - Compass 6HV - Vcontrol - Neo
#nodroneshere - 104
Larry227 is online now        Reply With Quote
Old 05-25-2010, 03:41 PM   #4
pamadren
Thanks for the help. Had to bind it for some reason. Had tail rudder not plugged into GYro. The settings on radio need to be reset and start over from factory. There is no option to select the swash type and swash mix settings. Not sure how the settings got off.
I rebuilt the 400 with some hop up billet items and need to get a viberation out of swash area.
Old 05-25-2010, 09:27 PM   #5
Larry227
Go to page 79 of the manual to see how to enter the setup screen for setting the swash type. (Press the ROLLER and hold while turning on the transmitter. When SETUP LIST appears on screen, release the roller.)
You're probably not seeing swash mix setitngs because the model is still set to 1servo 90*. Needs to be changed to 3servos 120*.
#nodroneshere - 104
