Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 425
Hurricane 425 Discussion and support of the Gaui Hurricane 425
Old 05-27-2010, 06:16 AM   #1
sven.herzing
Default Gaui 425 travel case
Hi,
does anybody know a travel case for the Gaui 425, or would it fit into a case for a Trex 500?
thanks
Sven
sven.herzing is online now        Reply With Quote
Old 05-27-2010, 02:49 PM   #2
spootman
I've seen various threads about people making cases for their 500 (430mm) heli's out of Bow cases (archery).
spootman is offline        Reply With Quote
Old 05-27-2010, 03:48 PM   #3
sven.herzing
In general it sounds like a good idea, but a bow case (or those I've seen) are quite likely a bit to big.
I bring my helis with the bus to the flying site, and the bus drivers started check the size limits(100x60x25cm), after I showed up a couple of times with a trex 600 in the bus.
I found this case(http://www.heliguy.com/Extras/Flight...luminium-Case/), which would fit the spec to make the bus company happy, but I'm not sure if 425 would fit, as I've read that it's a bit bigger as the trex 500.
Sven
Old 05-27-2010, 04:49 PM   #4
spootman
If it doesn't matter if it's a hard case, then you could try those carry bags from readyheli.com. It has the internal measurements for you to check.
Old 05-28-2010, 02:19 PM   #5
sven.herzing
Those might be an idea. I'll check them out.
