| Futaba Radios and Electronics Futaba Radios, Gyros, Servos, Etc. |
Greetings from Estonia
Has anyone tried to connect Futaba Receivers directly to the LiFe 2S (6,6V) battery? Does those (R617FS and R6008HS for example) survive fully charged LiFe voltage 7,2V? By Futaba specifications for 2.4GHz Receivers, the max voltage is 6V only. Any help would be appreciated Mihkel |
I run my Trex 600 on hyperion 6.6v 1700mah pack. No issue for me .
Trex 600NP Trex500esp |
they will run fine on a LiFe battery just make sure the servos and gyro are up for the task if not install a regulator for the gyro
Flying Hard makes it fun (AnimAL) To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. GrandRC Team Pilot |
I'm running the 6008 on 2S LiFePo - no problem at all
Rave 450 | Lepton | Logo 400/500/600 | Aeolus | Sceadu | Freya | Avant FX | Raptor G4 Gryphon field rep |
the 6106hfc has a power requirement of 3.3V~ 8.5 V
R6107SP 3.3V~8.5V the futaba s9070 is 7.2v servo
T-Rex550FBL,cgy750,bls256hv,kde upgrades,ice100,5800 T-Rex 250 se with gy520 , mks95i,R6008HS T-Rex 250 stock,R6106HFC mcpx, futaba12fgh, phoenix sim To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by babnika; 06-04-2010 at 03:40 AM.. Reason: added to |
#6 |
sorry weaking old thread..,
i have futaba rx 617fs on both of my heli, which rx spec voltage: 4,8-6V. My question: is this save to use LiFe 6.6V unregulated/direct to rx? because i don't want to burn my receiver which is only rated 6Volt
Trex 700e Vbar 5.3pro, 750MX 530kv JR260Z gasser dji ace one, Trex 450 pro flybar, Futaba 8FGS. |
#7 |
I personally run the following receivers on 2S LiFePO4 unregulated:
R6004FH R6106HFC R617FS R608FS R6008HS R6014FS R6014HS R6203SB R7008SB In addition, I have personally tested everyone of these receivers with a freshly charge 3S lipo and a 1.5 amp load (best I could do at the time). Again, no issues. The receiver is not the issue, it is the other equipment in you aircraft. Servos, gyros, etc. If they can handle the 6.6volts then no worries with the receivers.
AMA Leader Member Team Futaba Raptor 90SE/YS91ST - T550E FB - T550E FBL w/CGY-750 |
#8 |
are you sure the R617FS can handle 6.6volt from LiFe, because they rated max 6Volt only and difference from R6208SB Voltage Range: 3.7 - 8.4 Volt (2S Lipo capable).
my electronics can handle LiFe voltage anyway, my only concern is the RX lev jakarta
#9 | |
You are not going to hurt the 617FS RX by using an unregulated 2S LiFePO4 pack with it. Also keep in mind that when Futaba rates something at "6 volts" that is 6 volts nominal, so even a normal NiMH 5-cell (6 volt) pack is over 7 volts fresh off the charger. The 617 could care less.
#10 |
thanks for the sharing info bro, i will give it a try than
#11 |
When Futaba say 6v they mean 5 AA dry cells which is 7.5 volts
Even 5 & NiMH = 7v fully charged
