Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 06-01-2010, 10:36 AM   #1
Finless
Team Taco VP
Default Trex 550 Manual
Several have requested it and Steve Honnor took the time to scan it and sent it to me in PDF. Thanks Steve.
Here is the Trex 550 Manual. Thanks to Steve Honnor
Align Trex 550 Manual (6 Megs)
Additionally Align also now his it on their web site here. Thanks to camporroso for the link.
http://video.align.com.tw/mpeg/manua...rs/550E_3G.pdf
Enjoy,
Bob
Old 06-05-2010, 12:58 AM   #2
Wolfpackin
Here is the Flybar Kit Manual KX021005T:
http://video.align.com.tw/mpeg/manua...550E_Combo.pdf
Jonathan Livingston Helicopter
Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.)
CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG.
T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades.
Wolfpackin is offline        Reply With Quote
Old 07-13-2010, 04:11 PM   #3
cdkoho
Question 550 build videos
hey bob are you going to do a video on the 550 flybarless version align heli.i know you are busy but this would be a great build for beginners entering flybarless.
thanks mike
T-rex 450 v1
T-rex 500 CF
T-rex 600ESP
T-rex 450 PRO
Protos 500e
cdkoho is offline        Reply With Quote
Old 07-14-2010, 04:14 AM   #4
philipfrank
if you follow the manual it is about as easy as it gets.
it shows you step by step.
philipfrank is offline        Reply With Quote
Old 08-04-2010, 04:37 PM   #5
TimboZero
Finless,
I would be interested on your views of the manuals instructions on electronics placement.
They have the ESC mounted on the right side lower frame outer. I assume this to be a good idea due to it counter balancing the offset elevator and slightly offset rudder servos ?
Timbo
New Helicopter Pilot
Align 450SS with 3G mod , Align 550E Mini-VBar Blueline
Spektrum DX6i TX
TimboZero is offline        Reply With Quote
Old 08-04-2010, 04:55 PM   #6
Wolfpackin
And good for additional airflow for cooling.
Old 08-04-2010, 05:42 PM   #7
philipfrank
cooling only. no need for any counter balancing.
Old 08-05-2010, 12:12 AM   #8
TimboZero
You have all stuck with exactly as per the manual for electronics placement then ?
Old 08-05-2010, 12:55 AM   #9
beenflying
I surprised Align hasn't updated the manual, on their site, with the correct torque tube bearing placement (page 11). The latest kits come with an amended page, inserting in the manual.
beenflying is offline        Reply With Quote
Old 08-08-2010, 11:21 PM   #10
Chee
Hi Finless, I need the Trex550 manual, but I can download it. Please help, thanks! Chee
Chee is offline        Reply With Quote
Old 08-08-2010, 11:23 PM   #11
Chee
Sorry Finless, I mean I can't download it, please help. Chee
Old 08-09-2010, 07:44 PM   #12
Chee
Got it, thanks!
Old 09-07-2010, 11:07 AM   #13
Vazodian
Hello Bob,
Could you please do build vids on the 550E flybarless please ?
For me it is a reason to buy a heli or not
Vazodian is offline        Reply With Quote
Old 09-10-2010, 03:52 PM   #14
ducatirdr
Originally Posted by Vazodian View Post
Hello Bob,
Bob - If you plan on doing a build video soon let us know. I got mine today for my birthday and can go through this myself but I enjoy your build videos as it gives me that little extra confidence that I won't be screwing something up. I hate it when I do that
ducatirdr is offline        Reply With Quote
Old 09-30-2010, 05:20 AM   #15
LizardMan
My manual's page 11 shows, I think, that the bearing should be located 28.1cm (281mm) from the front end (connects to frame, not tail) and 29.6cm (296mm) from the tail end of the tube.
Is that figure correct?
LizardMan is offline        Reply With Quote
Old 09-30-2010, 05:46 AM   #16
beenflying
No. It should be 26.9 from the front and 31.8 from the tail, which is 3cm forward from the center.
Old 10-04-2010, 10:49 PM   #17
esmoglo
Still no parts page in the manual? Wonder why?
Angelo
Angelo
esmoglo is offline        Reply With Quote
Old 10-05-2010, 12:28 PM   #18
TJinGuy
Angelo
I don't see why anyone would need a parts list. Go to your favorite site, click on parts -> Align -> 550e and then find the picture of the part you need. That gives the bonus of being able to buy it right then.
- Chris
TJinTech heli...info...news...such
Helis: TRex 450 Pro - Protos - TRex 550e
Stuff: Spektrum DX7 - iCharger 208B - Hyperion G3
TJinGuy is offline        Reply With Quote
Old 10-07-2010, 04:14 AM   #19
LizardMan
Angelo
It was nice to see the parts list in my 450Pro manual. I wish those pages were also in the 550E manual.
Old 10-14-2010, 09:07 AM   #20
ducatirdr
Default VIDEO Setup 550E 3G Flybarless
I found this video on the 550E 3G Flybarless. While it's not a Finless production, it's a great help for those that like real pictures over black and white manual drawings.
I found nothing on the setup of the flybarless system. I found out why. Because its actually really simple to setup.
First set up the cyclic servo's off the heli just like Bob does in the 450 Pro video. Then install them in the heli and connect them to the control unit.
When you power up the heli for the first time you hold the setup button in on the control unit while you power up. (Quite a trick if you live alone )
This puts the FBL control unit in bypass mode.
Then check your cyclic servo's to see if the orientation is correct. If you set them up correctly before installing them in the heli they should still work fine. If not follow the Align instructions to correct the servo direction and cyclic + -. Bob's 450 Pro video is a great help on understanding the setup of cyclic servo's if you haven't done this before.
Once you get everything traveling in the right direction and have mid stick neutral dialed in on the head then you set up the control unit by following the step by step Align instructions. They are really rather simple once you read through them.
My JR 9303 setup is available if you would like it.
