Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 06-02-2010, 04:05 AM   #1
MoF65
Default 3G Cyclic Pitch Setup
The manual for the 550 says 12-14 degrees cyclic pitch when using the 3G and the manual for the 500 says 7-9 degrees. I have used 9 degrees cyclic on my 500 and it has worked fine. Should it really be that much difference on a 550 compared to the 500?
Does anyone have a config file of their 3G setup on the 550?
Morten
- Morten Fagermoen -
MoF65 is offline        Reply With Quote
