Lithium white grease, or automotive grease ?
Anything better for this?
HK Best Of Custom 450s & 500 Build Different! |
I use Tri-Flow "red" grease, available at most hobby shops.
+1 on the Tri-flow.
Trex 500-3226-1600, 13T, Koby 90LV, HS-5245MG, DS520, AR7200BX, DFC Trex 450 Sport-450M, 13T, RCE-BL35X, HS-5065MG, HSG-5084MG, DS760 DX8 |
Grey MolyB grease from Honda. you want something sticky and high-pressure.
had not heard of Triflow Red but looks interesting. |
Hi guys, I dont see any grease on the blade grips thrust bearings, that is the way that it came with, do I have to grease them ??
#6 | |
Trex250 Phoenix25, DS410 GP750 5084 AR6110 Trex450SEV2TT 4S Scorp-8 Phoenix45 CC10 Spektrum H3000 MKS-DS95i AR7200BX CopterX450ProTT 4S Typhoon2218 Phoenix35 HS65MG GP750 MKS-DS95i AR6100 Trex600E 8S 1910H/1Y HV85 5625MG Gy611 S9256 AR7000 |
#7 |
Does the Tri-flow sling out? Everything I've tried so far slings out after about 5 flights.
JR X9503 TREX 500 ESP FBL, Skookum SK720, Scorpion 3026-1600, 14T CHP TREX 600 ESP FBL, SK720, 8S, Scorpion 4025-740, 13T, WR Bec TREX 700E FBL, SK720, 12S, Scorpion Comm 130A ESC & 4035-500 , 12T, WR Bec To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#8 |
Believe it or not Ive been using Shooter Choice high pressure Pistol lube works great and doesn't sling off the bearings !
Helicopter: A mass of parts, all trying to kill you since the day it left the factory ! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#9 |
actually i see no ned for grease on thrust bearings of mini helis or smaller .. it does absolutely nothing for them except attract dirt .. all ive ever needed was a light oiling when i lube other things on the heli simply to prevent corrosion, grease them if it makes you feel better though ive never seen any benefit at all and only the detriment of if your not reeeeeal careful you'll get grit in them .. my advice .. dont worry about it ..
#10 | |
#11 |
+1 on no grease. I have plopped a drop of machine lube on occation, but primarily because I am lazy, but I don't think there is any grease that will stay put at 3000+ RPM. Never had any problems on my 450's without it.
#12 |
Out of ignorance or indifference I have never greased my CopterX v2 rotor heads and they have performed well and reliably for over a year.
Trex 450 SE V2 T-rex 500 ESP |
#13 |
VERY interesting to hear. I've been considering dropping the grease but haven't out of being a chicken. Other thing I'd love to drop is the grease on the dampners. Anybody see that as something I could drop on the small heli's too? The grease (cleaning and applying) makes it take longer to assemble a head.
As much crashing as I do anything to make that process faster is appreciated. |
#14 |
I can't imagine greasing my Blade CP Pro's. Heck, I use 3 mm I.D. ball bearings instead of dampers in them anyway.
