| 250 Class Electric Helicopters 250 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Just wondering if there is any major differences in these two NRG batteries except the 860 would provide what...25 seconds more of flight time if that? Thanks.
http://www.helidirect.com/outrage-nr...ma-p-17067.hdx http://www.helidirect.com/outrage-nr...50-p-17065.hdx is one preferred over the other, and why? I have four of the 800s already. Should I switch to the 860 or get the hyperion here. http://www.helidirect.com/hyperion-1...ck-p-12283.hdx Thanks for any help. Murph
Compass 6HV FBL Beastx- Shelved until I buy a new charger or switch to nitro or a gasser. Eflite Blade Mcpx Brushed |
The Hyperion is a very tight fit.
what about with a new style fusuno canopy?
Don't have it, but do have the larger align canopy. I didn't think the Fusuno was any bigger than the Align.
I've got the first version with, what they us to call, the lightning bolt canopy which was much larger than the origanal one. I think the SE is the same size as the lighting bolt one I have. |
#5 | |
The ground is only one dumb thumb away!!! Trex 600CF Silver,401/9253,60XL/75amp,all the metal bling bling 250v1 410's(5065mg's when I get a minute),750g,5084mg, hyperion battery( currently my favorite heli) 450SE V2 NUE 1107/2/H/2.3, CC45apm esc,770 3D/3400g,65mg,V_Blades,4s 21ooma Hyperions |
#6 |
I have a fusano canopy and the hyperion 850 and it fits fine. My canopy came already drilled and I didn't have to re-drill it.
#7 |
when did you get your canopy? I had to drill mine out.. the hyperions have no problem fitting under the new shape fusuno canopy.
Vergnugenstabi [adj.]pleasure/stability The enjoyment and feeling you get when flying a vbar. [farg-new-gen-stab-e] CF Logo 600SE/550SX Robert A. Team HAIYIN |
#8 |
nrg 860 mah's are the best battery for this heli in my opinion, the only battery i will use!
T Rex 250se--CC 25, scorpion 3900, hs65mg's, outrage 200 paddles, titanium turnbuckles, kevlar belt, quark/s9257, kbdd tail blades, Chinese weight mod, double thick canopy MSR--cusker blade grips/loads of CA glue |
#9 |
Where are you guys buying your 860mah NRG lipo's from as can't seem to find any in stock anywhere....?
Blade mCPx BL,130X, 250 SE,300x,Trex 450, Building - Goblin 500 Scorpion HKIII-4020-1100KV. Spectrum DX8 |
#10 |
#11 | |
http://store.rcsupersales.net/servle...NRG/Categories They look to be in stock but it looks like they are moving the store, though, and will be closed to June 16th. If that's not a problem for you I have no complaints about the NRG's that I bought from there.
mini-Prôtos, Prôtos 500, Nano CPx |
#12 |
I use both Outrage and Hyperions.
I used heli direct for the NRG's My LHS sells the Hyperions I use so that is local. The Hyperions are a tight fit in a stock SE canopy, I moved my canopy mounts forwrd 7mm to make it a better fit. The NRG's are shorter so those would not require the mod to the mounts.
Carl Trex 550E FS Vbar Pro 5.2- EXI-450T Mini Vbar Pro 5.2 - EXI 450T BeastX - Trex 250SE - mCPx v1 Hp05 & HP06 w/HP03t tails - AMA #952544 |
#13 | |
#14 |
exactly still waiting on that answer. not too worried about the whole fitment issue.
#15 |
I prefer the NRG's for fitment and ability to tweak the CG. Otherwise they have the same characteristics, i.e. Flight time, charge rate and, basically, capacity (10mah diff) Price point is the same from what I have seen, or a $1 diff at most.
#16 | |
http://www.rchobbyhelicopter.com/sto...licopter_Parts Manuel |
#17 |
Great, I thought I made a good decision! NRG's here I come.
I hope to recieve them today!!!! |
