Old 06-09-2010, 07:27 AM   #1
HuaHinEddy
Default T-rex 450 sport tail servo issue
Hi guys, i'm new to the hobby and have a question about my tailservo. It seems that after my first crash my tail servo does not go back to the center position. I'm not sure if that is the way it's suposed to be? if it's not..... (what i think! )is my servo dead now or can this be fixed? So for clarity, if i move my stick and let the stick go...my servo does not return to centerstick. please help!!
HuaHinEddy is offline        Reply With Quote
Old 06-09-2010, 08:46 AM   #2
Dr.Ron
If you're testing this on the bench that is what is supposed to happen. The tail servo won't move on the bench because its not sensing any movement to correct for via the gyro.
If you turn the tail hard on the bench does the servo move? Does it sound like its powered on when everything is initialized?
You may have stripped the gears in the servo or the servo is trashed. A way to check the servo itself is remove it from the frame, plug it into another channel on the receiver and see what happens. I'll usually unplug the ESC from the throttle channel and plug a servo into that channel and than test it by increasing and decreasing the throttle on the Tx. Stripped gears can be replaced, but a trashed servo will need to be replaced totally.
Good Luck!
Ron
Dr.Ron is offline        Reply With Quote
Old 06-09-2010, 08:54 AM   #3
johnsma22
The tail servo will not go back to center when the gyro is in heading hold mode. It will return to center in rate mode. What gyro and radio are you using?
johnsma22 is online now        Reply With Quote
Old 06-09-2010, 10:48 AM   #4
HuaHinEddy
i use a GP780 and a T6EHP radio
Old 06-09-2010, 04:45 PM   #5
johnsma22
I don't know how you set the gain with that radio, but with the 780 gyro the little LED on it will be green in heading hold mode and red in rate mode. If the LED on the gyro is green and the tail does not go back to center after you give it some rudder input, that's completely normal.
