Old 06-09-2010, 10:51 PM   #1
sly the dogman
Default locktite on carbon
Putting servos in a carbon frame, but I do not have those small
plastic things that go in the back of the crews to hold the servo
secure. Not a good idea to put locktite on the screws
on the inside of the carbon frame, right ?
sly the dogman is offline        Reply With Quote
Old 06-09-2010, 11:25 PM   #2
Aussie_phoenix
With the SEV2 frames I have always just cut the end of old servo horns (keeping last hole intact) and put that on the other side of the frame. Screw a self tapper through the servo hole/frame hole/into the plastic nut (the one just fabricated from the end of an old servo horn) and put a dab of CA glue on the end. Never given me any problems and if you cut the old servo horn at the right spot the flat edge from where you cut it will hold against the side of the servo so it will not spin.
Trex250 Phoenix25, DS410 GP750 5084 AR6110
Trex450SEV2TT 4S Scorp-8 Phoenix45 CC10 Spektrum H3000 MKS-DS95i AR7200BX
CopterX450ProTT 4S Typhoon2218 Phoenix35 HS65MG GP750 MKS-DS95i AR6100
Trex600E 8S 1910H/1Y HV85 5625MG Gy611 S9256 AR7000
Aussie_phoenix is offline        Reply With Quote
Old 06-10-2010, 01:47 AM   #3
Viet-Lama
+1 to AP, I did the exact same on my 450s and it works a treat.
Every time I crash I wonder, why didnt I get into RC tanks.
Viet-Lama is offline        Reply With Quote
Old 06-10-2010, 08:13 AM   #4
sly the dogman
Cool idea, I'll try that.
Old 06-10-2010, 08:56 AM   #5
flerpie
I've never mounted a servo using the plastic thingys.
Those go in the trash.
Nuts, bolts and washers and locktite are the way to go.
HK Best Of Custom 450s & 500
Build Different!
flerpie is offline        Reply With Quote
Old 06-10-2010, 01:36 PM   #6
sly the dogman
Well, I tried them on for size. The servos have never been more
solidly fixed than now. When I try to move one the whole side of the frame
flexes (carbon you see). PITA to install, but hey, if it works, its worth it.
Thanks,
later
Old 06-10-2010, 06:23 PM   #7
Michaelinpr
Awesome idea. I have a ton of old servo horns from when i used to use those crappy $3 servos from HK.
Michaelinpr is offline        Reply With Quote
