Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCX
mCX Blade (eFlite) Micro CX Helicopters Information and Help
Old 06-13-2010, 03:52 PM   #1
MonkeyKnight
Default mCX main inner shaft mCX2
So I went to the local hobby shop today to get yet another inner main shaft for my mCX, because it seems to be the only dang part that gets broken in a crash. A buddy of mine went to the shop for the same reason and a guy behind the counter had mentioned that maybe the mCX2 part would bolt onto the mCX. Sure enough it does. Maybe this is a commonly known thing with the introduction of the mCX2, but it was news to me. Just thought others may benefit from knowing this.
ID:	162753   Click image for larger version
ID:	162754   Click image for larger version
ID:	162755   Click image for larger version
MonkeyKnight is offline        Reply With Quote
Old 06-13-2010, 06:19 PM   #2
ChrisH
Yep it is a direct fit and much stronger than the stock mCX piece.
Edge Rotorblades
Thor/Voltz Batteries
450 Pro V-Bar
130X
ChrisH is offline        Reply With Quote
Old 06-16-2010, 08:54 AM   #3
acerpower
This is good to know.
Thanks.
acerpower is offline        Reply With Quote
Old 06-24-2010, 11:52 PM   #4
heyheyuw
I just installed an mCX2 inner shaft and swash on my mCX tonight. So far, so good...
It didn't take much tweaking to get it trimmed right up.
Cheers,
Chris
heyheyuw is offline        Reply With Quote
Old 06-25-2010, 11:43 PM   #5
MonkeyKnight
Awesome, let us know what you think of the mCX2 swash, I installed an mSR one myself - love it.
Old 06-26-2010, 02:57 PM   #6
heyheyuw
It definitely flies differently now... It is faster in forward flight, but is more susceptible to falling through with fast left rudder or rudder/aileron turns during forward flight. After crashing a few times, I'm starting to see some TBE, but I've been putting a lot of cycles through it, and I think parts are starting to wear.
I definitely think it's more fun to fly with the mCX2 swash... I especially like the fact that it doesn't separate after every crash like the mCX swash does. :-)
Cheers,
Chris
Old 06-29-2010, 09:19 PM   #7
MonkeyKnight
I like how the mSR one doesn't come apart compared to the original sorry excuse for a swash.
How much different are the mSR and mCX2 swashes? On MH they say that they are compatible.
Old 06-29-2010, 10:05 PM   #8
heyheyuw
I was looking at them today, and they look pretty much the same with my calibrated MK 1 eyeball... :-)
I just got done futzing with my mCX and have found out I burnt out the five in one. I broke a landing gear, and while pulling it out, broke the tab into the frame. when I went to replace the frame, I got it all together only to find that the elevation servo is toast. Ack.
Oh well... I've got a donor machine now. Time to get another.
Old 02-26-2011, 06:17 AM   #9
Dirty Mexican
Default mCX2 blades on MCX
I just tried to put the mCX2 inner shaft, flybar and upper and lower blades on my mCX. It seems to fly a bit faster, but a little more heavier. Any ideas on how to lighen it up or should I just go back to mCX blades?
Dirty Mexican is offline        Reply With Quote
Old 02-26-2011, 09:47 PM   #10
ChrisH
They should be identical, other than coloring. Psychological change?
Edge Rotorblades
450 Pro V-Bar
130X
Old 02-27-2011, 09:11 AM   #11
Dirty Mexican
You are more than likley right!
Old 02-28-2011, 08:16 PM   #12
jerrysec
I've got the mcx2 inner shaft and the swash plate mod along with the flybar on my MCX. I'm also still use the stock blades. I've also put on a Xtream canopy. The MCX will fly circles around my MCX2 now. I've tried the blades from the MCX2 and worked fine. You do get a bit more lift with them, but they are also a little heavier I think. I'm used to the speed of my MCX now and need to speed up my MCX2.
jerrysec is offline        Reply With Quote
