Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 425
Hurricane 425 Discussion and support of the Gaui Hurricane 425
Old 06-15-2010, 10:33 AM   #1
microhelijon
Default 425 V2
check it out Gaui 425 V2 in Europe
http://www.pitchup.se/index.php?page...at=13&group=11
microhelijon is offline        Reply With Quote
Old 06-15-2010, 12:24 PM   #2
KCMike
The X4 -- wow, pretty sweet! I searched for it on Google & found the following ...
From Feb:
http://helifreak.com/showthread.php?t=190389
Gaui 425 V2 Presentation:
My YouTube Channel: http://youtube.com/DarthTedd
Xbox Live - TheBiffTannen
KCMike is offline        Reply With Quote
Old 06-16-2010, 02:03 AM   #3
Jerrymac
I could be wrong, but it looks kinda pricey to me. If I guessed right it would be about $530 USD.
I don't need the latest and greatest. I just need more time to fly what I have.
Align 450 Sport V2, Gaui 200, Gaui 425 x 2, "HeadHunter 500, Gaui 550, all Flybar'd
Jerrymac is offline        Reply With Quote
Old 06-16-2010, 02:11 AM   #4
Mikej
That came out a while back - a mix of early 550 / 425 parts (head, gears etc.) and some X5 bits (frame desin etc.). Only from Pitch Up and expensive
Mikej is offline        Reply With Quote
Old 07-14-2010, 12:56 AM   #5
microhelijon
Any Swedish friends can kind enough to share more info about this V2
Love to learn more about its carbon frame... for my Hurri550
Jon
Old 07-26-2010, 01:22 PM   #6
joe1l
Looks like the same head i'm running. but with a direct servo to swash diesign...
Gaui X7 MSH Brain YGE160HV Xera4035-480 Gaui X475 FES MSH Brain YGE120 Xera4020 Gaui X5 MSH Brain YGE90HV Xera 4025
Gaui X6 vbar silver 5.3 YGE120HV 700mx
joe1l is offline        Reply With Quote
Old 07-27-2010, 04:34 PM   #7
nexgen
It seems that this bird was a test bed to probe new servo layout, and frame design impact on performance. also to expose customers to something different from Gaui to gauge response. when it first came out there was a fair amount of 'chatter' about it, so I think Gaui decided to run with it and redesign the whole works ala the X5.
Gaui 200 •Gaui 550 •Gaui X5
BeastX Castle Scorpion Hyperion Spektrum JR
The Front Porch, Nexgens Lounge
nexgen is offline        Reply With Quote
Old 07-29-2010, 11:46 PM   #8
microhelijon
Looking... Closely again at the motor mount location makes me wonders.. If bigger motor can is going to be an issue... Look how close those cyclic servo are to the motor...
Jon
GAUI X4 -CC75 / 8s / mini V bar
ALIGN TREX 600EFL PRO - Jive80HV / BeastX / 12s
Old 12-31-2010, 11:46 PM   #9
microhelijon
Any friend in/from Europe can share more info about this X4..
doesnt seem to see/hear alot about it..
Old 01-01-2011, 03:32 AM   #10
fusionsx00
Pretty much what im building 425cf frame tt tail
x5 head, looks alot better than the plastic 425
finally gaui hears our crys
fusionsx00 is offline        Reply With Quote
Old 01-01-2011, 03:39 AM   #11
fusionsx00
So far im in 270$ that's including the fes x5 head, 60amp esc 504 motor
tt tail, cnc tail, cf frame, not bad for a higher end 425 heli.
all new parts
Old 01-01-2011, 04:49 AM   #12
microhelijon
Take a closer look at the X4..it has got no push/pull linkages veri neat
I am on the 425 gf frame
share your pic, Fusionx00
Old 01-01-2011, 03:32 PM   #13
fusionsx00
Will do asap, im working crazy hours right now, ill do it sometime this week
Old 01-10-2011, 05:34 AM   #14
fusionsx00
Default pics of my aka x4
Here are some pics of my frame with the x5 yoke
and my torque tube tail, I guess I got the 425long one so I cut the tt drive down to fit
im using the gaui 425 _carbons
ID:	200488   Click image for larger version
Old 01-10-2011, 07:24 AM   #15
microhelijon
Thanks for sharing...looks good.
good luck with the mod..
Old 01-17-2011, 03:37 AM   #16
fusionsx00
Default more pics
Moving along on my build, mounted another cnc motor mount for my sk-720
im trying to keep it as far away from my electronics, and finally found the spindle bolts.
tommorow im going to mount my servos,esc,powerbus,tail,blades anything else missing
I will find out tommorow.
Im still gona get my canopy painted to say x4
ID:	202055   Click image for larger version
ID:	202056   Click image for larger version
Old 01-17-2011, 08:43 PM   #17
jyheli
Default question
Boom
- WHat is the boom diameter of 425V2 ? Is it the same for 550?
- Do 425V2 boom same as that of Gaui X5?
Main rotor head
- What is the main shaft diameter ?
- Is the 425V2 main shaft same as that of Gaui x5 ?
thanks in advance
Jonathan
DX18 ; Forza 450 , Energic Slope/E glider , Snipe DLG
jyheli is offline        Reply With Quote
Old 01-18-2011, 12:13 AM   #18
fusionsx00
i don't think there is a" v2" but the cf frame could be considered that
The boom diameter's are the same for the 425 and 550
the drives im not sure but the drives fit right in so they should be
I don't know the boom diameters
The main shaft is 8mm for the 425,550, and x5
I know this because I am using a x5 yoke on a 425 main shaft
The 425, are pretty much the same except the 550 uses a longer boom, and blades
Belt or ,torque drive which ever your using
Old 01-18-2011, 12:20 AM   #19
Seebodener
Originally Posted by jyheli View Post
Main rotor head
thanks in advance
Jonathan
diameter is the same, but length is different, see: http://www.helifreak.com/showpost.ph...02&postcount=4
Jörg
* fly fast - live slow *
Seebodener is offline        Reply With Quote
Old 01-19-2011, 08:26 AM   #20
jyheli
Seebodener, fusionsx00,
Thanks for your info.
Jonathan
