Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 06-18-2010, 10:32 AM   #1
RKH-DSN
Default One idea to upgrade!
I have an idea upgrade boom mount look better and more durable. It takes me about 30hrs to complete Cad drawings as below.
It's heavier than stock about 12.3g. Looking forward your ideas!!!
My friend have a 4 axis cnc machine, so I think he can help me to make some sample. I hope it works well. And i will take and post real photos after he had time to do it
RKH-DSN is offline        Reply With Quote
Old 06-18-2010, 11:42 AM   #2
SpeedDemon46
Wow - Design looks very slick. I can't imagine how much work it must be to design something like this. Very, very cool. Keep us posted on how it turns out!
E-Flite Blades: mCX, S300, CX3, mSR, SR, 400, mCPX
Align TRex 550E 3G w. KDE Direct 1907
AMA #: 948082
SpeedDemon46 is offline        Reply With Quote
Old 06-18-2010, 03:23 PM   #3
Cailid
If that lets you change the front gear without having to remove the entire thing from the heli then I think just about everyone would want one.
I wonder how long now before 'someone' posts that he 'just found' a picture of that exact thing on aligns web site as being released in 1-2 weeks.
MCX, CX2, MSR
Blade 400, 500ESP, 500CF
Cailid is offline        Reply With Quote
Old 06-18-2010, 05:27 PM   #4
RKH-DSN
Yeah! Your idea is very good! I have not though up to this point when designing...humm..I thinks it also is not easy
Old 06-18-2010, 08:36 PM   #5
rmaxson29
Very nice Design
rmaxson29 is offline        Reply With Quote
Old 06-19-2010, 01:52 AM   #6
helicopter-nguyen
I think this not be possible. Because removing front gear upward will be prevented by Main Gear. Removing front gear downward will be prevented by horizontal bevel gear, And removing front gear sideward will be prevented by side frames.
Replace the front gear by removing the boom mount as present is not too difficult. I think this was the easiest way.
helicopter-nguyen is offline        Reply With Quote
Old 06-19-2010, 02:35 AM   #7
Spork01
You mean this IS the only way. easy it is not . Removing the gears is easy, putting a new one in is tough as hell. took alot of strength to push the new torque gear into the bearings. I had to use a little sandpaper, grease and alot of muscle.
Trex 450 Pro V2 FB spartan quark
trex 250 beastx
Fusion 50 beastX
Spork01 is offline        Reply With Quote
Old 06-19-2010, 08:28 AM   #8
Jimmy_Heli
Today,My Trex550E crashed , Boom mount has been cracked . I think you should make your boom mount by Aluminum 6061
Jimmy_Heli is offline        Reply With Quote
Old 06-19-2010, 09:13 AM   #9
Jimmy_Heli
Good idea
Old 06-19-2010, 09:28 AM   #10
helicopter-nguyen
By principle of Align, bevel gear must be tight with bearing. If not it will be pushed forward by Torque shaft and make gear mess worse. So you have to use special tool to assembly or remove bevel gear.
To fix this, I think we have to use another principle (ex: Kasama's principle...)=> we have to change a lot of Align part. And our Upgrade are very expensive!
Old 06-19-2010, 09:32 AM   #11
RKH-DSN
Originally Posted by Jimmy_Heli View Post
Today,My Trex550E crashed , Boom mount has been cracked . I think your boom mount should make by Aluminum 6061
Yes, I designed it made of aluminum 6061.
Old 06-19-2010, 10:52 PM   #12
philipfrank
wow, that would be nice. i'd be interested to see a price on something like that.
it'd be a work of art.
i wish all of the finish on the 550 aluminum was polished silver. not a big fan of anodizing any color other than polished to a shine silver.
on the boom mount, it would be nice to use thru bolts and nuts as opposed to tapped threads that could strip in the aluminum mount.
of course i'd probably go with it either way if it didn't break the bank.
i look forward to seeing what you come up with. bless you for even trying.
philipfrank is offline        Reply With Quote
Old 06-20-2010, 08:54 AM   #13
helicopter-nguyen
Yeah, It has sophisticated design as Kasama's products. I don't know if it's as expensive as Kasama's one!?
Old 06-20-2010, 04:40 PM   #14
Buzzard
First offf great thinking. But I think the easiest fix would be to make the rear gears softer and the front harder in case of a crash. And you could put your hard work on making a new rear tail which makes it easy to switch tail gears. I just dont get it, all my trex helicopters always trip teeth from the hard to reach front gears when they could easliy design it so you just took 3 screws and swaped out rear TT gears. How long will it take align to rethink this idea? I never strip my rear umbrella gears!
Buzzard is offline        Reply With Quote
Old 06-20-2010, 04:45 PM   #15
sacko
Yup, that idea works perfectly on the Velocity 50 and takes about 3 minutes to change a gearset
..no reason it wont work on an Align model.
Trex 500ESP - Vbar v5, MKS 9660A, BLS251,
Outrage Velocity 50 - Vbar v5, Futaba BLS 351, Outrage 9080, OS55 all @ 8v
Kasama Srimok
sacko is offline        Reply With Quote
Old 06-20-2010, 05:44 PM   #16
Jthief
Why not use 6061 on the front gears?
Jthief is offline        Reply With Quote
Old 06-20-2010, 05:49 PM   #17
Buzzard
Im sorry for being ignorant here but can you clue me in to what your talking about? Im tired of taking inner TT gears out. If you got a solution share man!
Old 06-20-2010, 09:12 PM   #18
Jthief
metal gears
Old 06-21-2010, 12:31 PM   #19
Buzzard
hrm. Isnt there a reason they use a nylon like material? I think it has to dio with smoother gears or somthing. I was gonna sugest a harder plastic like they did on the old trex 450's several years ago.
Old 09-25-2010, 02:22 AM   #20
helicopter-nguyen
oh! They've released them! The price is high but look very cool!
http://www.rakonheli.com/rkh/index.p...emart&Itemid=1
Has anyone tried it?
