| Skookum Robotics Skookum Robotics SK-360 SK-540 & SK-720 Digital Flybar |
#21 |
Information no longer pertinent, so I removed it.
Jose (Youtube -> Silverexpress01 See also Helifreak Blog) MCPx 76/7 | Trex 250 DFC 667/19 | Hurricane 200 FES 143/7 Last edited by Silverexpress01; 08-10-2010 at 01:45 AM.. |
#22 |
Lasse:
It sounds like the micro-sd card has a problem, not the unit itself. It's possible to (carefully) remove the micro-sd card using a very small tip flat screwdriver or a dull #11 exacto blade tip. You could then either format it with an adapter on your PC, or replace it with another 2gb card. You'd have to rename the card SK720 by (right-click it in windows explorer) before it will be recognized though. NOTE: If the micro-sd card is in the unit, format it using the SK720's software, not using windows! |
#23 |
Problem solved
I had to rename the drive to SK720. Thanks Art ![]()
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” Align 480 Pro 6s. Mini V-bar 5.0 PRO Blade mCP x To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#24 |
I think my problem was operator error. I seem to remember disconnecting the cable this morning before I tried it the second time. I guess I didn't get it seated properly when I reconnected.
Today at lunch everything worked just fine. I also tried the S/L feature and that also worked well. I didn't try anything drastic, though. |
#25 |
How did it get renamed?
#26 |
I did a fomat directly from the computer, not in the SK software
#27 |
I can only fixed one out of two of mine ....
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. - we ship worldwide free; SK 720, SK 360, DS 760, GyroBot .....mostly FBL only, the good products only To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#28 |
HeliFreak Security Staff
Win 7 64Bit, update went fine.
MSH Protos FBL SK720 Trex 600 14S A123 CCHV110 Actro 24-3 Trex 600 AP 12S A123 CCHV85 NEU 1912 1y Gaui 200 Trex 450 SE V2 Dedicated night Rig |
