Old 06-23-2010, 12:13 PM   #1
Lynx.1677
Default Align 450 Pro - What Scorpion motor?
I'd like to get a pretty mad 450 on the go. I have a 450 Pro with the old SP motor but I want to replace that with a Scorpion motor. What is the best choice?
-6 or -8?
I've heard the -6 is insane.
I'm learning 3D so want something that will be suitable later when I improve.
Also, what would the best pinions and ESC choices be?
I'm thinking 12t for the -8 and 11t for the -6 and a CC50 but not quite sure which model I am looking for. I've found one called Castle Phoenix 50 but do you need an external BEC or is the internal one good enoug?
Is 4S worth considering?
A quick vid of where I am at flying wise:
Thanks all,
Dan
Trex 500 Pro
MCPx v2
130X
DX7
Lynx.1677 is offline        Reply With Quote
Old 06-23-2010, 07:19 PM   #2
Aussie_phoenix
If you want to stick with 3S then I would say go for the Scorp-6 with 12 tooth pinion governed in "set rpm" mode on your ESC. 4400kV 525 Watts.
If you want the flexability of 3S or 4S then go with the Scorp-8, 13 tooth on 3S and 11 tooth on 4S governed in "set rpm" mode on your ESC. 3595kV and 475 Watts.
if you want 4S only then the Scorp-10 is probably the motor for you (not sure how you need to gear it). 3000kV 550 Watts.
See Scorpion comparison page below
http://www.scorpionsystem.com/catalo...&p13=72&p14=70
I can only really speak for the Scorp-8 and love it on 4S - more power than I will ever need. Just make sure you put in ceramic bearings .
Trex250 Phoenix25, DS410 GP750 5084 AR6110
Trex450SEV2TT 4S Scorp-8 Phoenix45 CC10 Spektrum H3000 MKS-DS95i AR7200BX
CopterX450ProTT 4S Typhoon2218 Phoenix35 HS65MG GP750 MKS-DS95i AR6100
Trex600E 8S 1910H/1Y HV85 5625MG Gy611 S9256 AR7000
Aussie_phoenix is offline        Reply With Quote
Old 06-24-2010, 07:49 AM   #3
Lynx.1677
Thanks Aussie. You sure seem to know your stuff when it comes to Scorp. I'll give the -8 a go on 3S and see how she fares.
Thanks!
Trex 500 Pro
MCPx v2
130X
DX7
