Go Back   HeliFreak > R/C Helicopter Support > Synergy Model Helicopters
Synergy Model Helicopters Synergy Model Helicopters Support
Old 06-24-2010, 05:03 PM   #1
Blades345
Default Anyone know a good place to put a header tank on the N5?
Trying to figure out a good spot to put a header tank and which header tank to use. That control rod on the right side of the heli seems like it would get in the way some. The reason I am wanting one is to keep the pressure consistant throughout the flight so my engine doesn't run leaner at the end of the flight,, which is happening now! I am running an OS55.
When you don't feel like soaring through the wind with a plane,, BEAT IT INTO SUBMISSION WITH A HELI!!!
No helis right now! Maybe I'll be back in another year!
Blades345 is offline        Reply With Quote
Old 06-24-2010, 05:07 PM   #2
beeflyer2
Get an OMI fuel magnet. Works very well.
beeflyer2 is online now        Reply With Quote
Old 06-24-2010, 07:37 PM   #3
Blades345
Already have one on there, but it will still tend to run leaner at the end, due to pressure not being as great. A header tank will fix that!
Old 06-29-2010, 08:53 PM   #4
chugga-bug
I've stuck mine to the main tank with double sided tape, and sealed all round the joint with silicone.
Works well
chugga-bug is offline        Reply With Quote
Old 06-29-2010, 09:18 PM   #5
Hulley
Works well
That is a damn good idea!
Hulley is offline        Reply With Quote
