Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 425
Hurricane 425 Discussion and support of the Gaui Hurricane 425
Old 06-25-2010, 05:46 AM   #1
snowflakes
Default Is it possible to use the same motor for 425 and 550?
Just yesterday got my hands on a gaui 425 kit.
Now I'm taking the time to find out what electronics to put in.
In the future I want to extend the 425 to a 550, So I'am wondering if there is a motor-setup which can be used for flying 425 first, and lateron for 550.
Looking at the motors used for a 550 they are about 1000Kv
--> Can I use this (with different gearing/pinion) to get enough headspead for a 425?
Hoping some of you guys has some experience with this.
Thansk
CopterX 450 _ T-rex 250 _ Walkera CB100
Gaui Hurricane 425 (under construction)
Spektrum DX6i
snowflakes is offline        Reply With Quote
Old 06-25-2010, 07:49 AM   #2
Mikej
I set my 550 up as a 425 for a while using my Z20A 980kV - it flew OK, but probbaly not up to 3D (but neither am I ). If you went for a 1100Kv motor with a 16 / 42 / 20 / 61 gearing that should get yopu up to about 3,000 HS. Then stick on 14 / 60 /20 61 and you are back down at 1,800 HS.
Mikej is offline        Reply With Quote
Old 06-25-2010, 08:42 AM   #3
spootman
I got a good deal on a scorpion 3026 1000kv and tried it my 425, it was good enough for sport flying (which is all I can do) but didn't have any power for punch outs.
spootman is offline        Reply With Quote
Old 06-25-2010, 09:13 AM   #4
Epoweredrc
oh yeah, so what need lower KV? 900 or not sure what all they make.
did you play with the gearing or know what HS you was at
,B450 w.HS65MG,ZYX Tarrot Head FBL, Billowy Batterys ,MCPX BLack dragon oversky 10a, Blade CP pro BL
Epoweredrc is offline        Reply With Quote
Old 06-25-2010, 12:26 PM   #5
snowflakes
Thanks for the fast replies guys! Gives me a warm feeling
I'm going to do some motor-shopping this evening
Spektrum DX6i
Old 06-26-2010, 06:26 PM   #6
spootman
I was running somewhere between 2500-2600 for head speed.
Old 06-26-2010, 09:19 PM   #7
Epoweredrc
and thats not enough for 3D?
gues sif you flew a 450 sized you be running 3,000HS myself i run 2600 on my blade 400
