Old 07-01-2010, 10:16 AM   #1
ItalianHeli
Default Scorpion Motor question!
Hey guys! Can someone tell me how to properly lubricate the scorpion motor? Is the removal of the motor necessary to lubricate? Thanks
ItalianHeli is offline        Reply With Quote
Old 07-01-2010, 11:35 AM   #2
05RAVEN
No, that would suck pulling the motor out every 5-10 flights. Just a drop of oil on the upper bearing under the pinion then flip the heli upside down and add a drop on the bottom bearing through the cooling hole.
T-Rex 500ESP- BeastX, Radix blades, Scorpion 1600kv
T-Rex 450 Pro- Scale MD500D, DFC head, AR7200BX, Radix blades,
SPEKTRUM DX8
05RAVEN is offline        Reply With Quote
Old 07-01-2010, 12:23 PM   #3
Cadjocky
This will help you with oiling the motor. It comes with a long tip to get down in the motor.
http://www.readyheli.com/OilKit-Scor...t_p_35764.html
RIP
BEAM E4 ~ds760+S9257~HS-5065~2221-8~ CC45~Eagletree+GPS
250SE~CC25+Scorpion 3900~HS-65HB~Quark~DS290~All metal ugrades~KDE
Cadjocky is offline        Reply With Quote
Old 07-01-2010, 01:26 PM   #4
Starcruiser
+1
This is what I do to my 2221-8 on my 450, the 250 may end up with a 3900 soon
Also the CC ESC's rock.
Carl
Trex 550E FS Vbar Pro 5.2- EXI-450T Mini Vbar Pro 5.2 - EXI 450T BeastX - Trex 250SE - mCPx v1 Hp05 & HP06 w/HP03t tails - AMA #952544
Starcruiser is offline        Reply With Quote
Old 07-01-2010, 06:00 PM   #5
ItalianHeli
Thanks guys!
