Old 07-05-2010, 10:14 PM   #1
wolfy
Default Will an Ice 50 Fit?
I spent the morning setting up the head on my 450 Pro for proper pitch. So I did a lot of plug in, unplug, plug in, etc. Now my Align 35 won't arm. Servos move but the motor won't arm. I'm thinking of replacing it with an Phoenix Ice 50.
Will a Phoenix Ice 50 fit in the space under the batt tray on the 450 Pro? Any recommendations? Ice or Ice Lite?
wolfy is offline        Reply With Quote
Old 07-05-2010, 11:31 PM   #2
snjbird
Here is a thread I started when I added a ICE lite 50
snjbird is offline        Reply With Quote
Old 07-05-2010, 11:37 PM   #3
CatchmyCorsair
Running ICE 50 Lite under the tray. Fits tight but fine. Been running 100% throttle all summer in 90F+ heat, no problems with hard flight.
Steve
Trex 450 Pro
= MSH Prtos = E-Stratus
CatchmyCorsair is online now        Reply With Quote
Old 07-06-2010, 01:12 AM   #4
snjbird
Mine gets hot, But I am using the governor, and that stands up to reason...
Old 07-06-2010, 01:45 AM   #5
Robban
I am not sure that the CC Ice 50 will fit under the battery tray, but the CC Ice 50 Lite will!
Align Trex 450 Sport, GP750 gyro, HS-65MG, DS420, CC Ice 50 Lite, Align 325D CF Blades
Align Trex 450 Pro, GP750 gyro, DS410M, DS520, RCE-BL35X 35A, Align 325D CF Blades
Spectrum DX7
Robban is offline        Reply With Quote
Old 07-06-2010, 05:20 AM   #6
sarpilot
http://www.helifreak.com/showthread.php?t=225904
see page 2
"It's not the crash so much as the sudden stop"
Compass 7HV, Compass 6HV, TRex450Pro, bunch of other junk in boxes ... Team Flybar Team Tail-In wannabe....
sarpilot is offline        Reply With Quote
Old 07-06-2010, 07:34 AM   #7
MatsSweden
The ICE 50 will fit under the battery tray, it's tight, and it'll be a whole lotta cursing getting it there. But yes, it fits.
I'll try to take some pics later.
/Mats
MatsSweden is offline        Reply With Quote
Old 07-06-2010, 09:34 AM   #8
D Grade
I have an ICE 50 ESC, and yes, its a royal pain to try to put under the tray. I had mine mounted on the side but moved it to the bottom centered under the main shaft and strapped to the main frame (not going ANYWHERE). I like it there, better center weight and PLENTY of airflow to keep it cool.
T-Rex 700LE x2 T-Rex 600LE x2T-Rex 600ESP T-Rex 500ESP x2 ElyQ Vision 50 - OS55, B320
Flown via DX7
D Grade is offline        Reply With Quote
Old 07-06-2010, 01:43 PM   #9
wolfy
Thanks for the responses! Heating up the soldering iron now...
Steve
Old 07-06-2010, 05:48 PM   #10
cruehead00
Hi, Yes the standard ICE50 will fit under the tray but I ended up cutting the tray a bit just above the canopy clip to give the wires some room. I also had to put the ESC on its side as it is too wide for the frames. I'll probably invest in a KDE battery tray to make things a little easier and less of a cram. If anybody has any pics to share of how they did theirs I would love to see them. I'll see if I can upload some of mine. Good luck, you wont be disappointed with the ICE though!
cruehead00 is offline        Reply With Quote
Old 07-07-2010, 12:36 AM   #11
D Grade
+1 for the ICE 50....75, 85HV, 100, and 160HV. I got em all, lol.
Will post pics later of how I have my 50 mounted on my 450.
Flown via DX7
Old 07-07-2010, 07:59 AM   #12
brentonasmith
it can be done but it's a PITA.............but well worth the effort IMO.
logs show no evidence of overheating flying light 3D in moderate ambient temps
TREX 450 PRO DFC - 2221-8 V2 (3S), ICE50, AR7200BX, HS65MG, DS3500G, KBDD Tail Blades
RAVE 450 - 2221-10 (4S), ICE50 Lite, Quark, DS285, DS3500G, 6100E, KBDD
brentonasmith is offline        Reply With Quote
Old 07-08-2010, 04:59 AM   #13
monkey1
just fit put it under battery tray
Trex450Pro, 10CHG, GP750, ICE50, Scorpion HK2221-8, MG933x 3, MKS8910
monkey1 is offline        Reply With Quote
Old 07-08-2010, 07:16 AM   #14
D Grade
As promised, here are pics of my underside mounting. Not even that noticable with the canopy on.
ID:	167031   Click image for larger version
Flown via DX7
Old 07-08-2010, 04:16 PM   #15
sarpilot
Is that the KDE battery mount package?
Old 07-09-2010, 06:19 PM   #16
brentonasmith
yes it is, and I highly recommend it.
I have had two hard crashes which slightly bent the battery mount that would have otherwise taco'd packs. in both cases I've bent it back in shape, not perfect but good enough.
pricey but worthwhile investment IMO, given I use Hyperion packs I think it's paid for itself.
Old 07-10-2010, 04:54 PM   #17
sarpilot
thx... it looks nice and will give my ice lite 50 some breathing space....
