Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 425
Hurricane 425 Discussion and support of the Gaui Hurricane 425
Old 07-09-2010, 09:43 AM   #1
rotorsup
Default Any tail issues?
Hello all - Just ordered my 425 with Pro 3D 430mm blades from HeliFlightCenter.com. They offer free shipping on orders over $100, and the total came out to $101.41. Pretty good deal I think.
http://www.heliflightcenter.com/HURR...p/g-204399.htm
Anyway, my question is related to the tail design on the 425/550. It's my understanding that the 425 and 550 share many parts in common, so I began watching Finless Bob's build videos. The very first one (an update), describes a problem with the tail at high head speeds. The video can be found here (again, it's the very first one):
http://helifreak.com/showthread.php?t=31211
This is a pretty old video, so maybe Gaui has corrected the problem by going to a thrust bearing in each grip. But my question is: Has anyone had the tail lock up (causing a severe piro) when running at higher head speeds? Bob's "fix" is to use a portion of a tail from a different heli. I was hoping NOT to have to do this.
Just wondering if anyone has had problems with this.
Thanks.
rotorsup is offline        Reply With Quote
Old 07-09-2010, 11:55 PM   #2
Jerrymac
Gaui makes a thrusted tail grip assembly now. I can't remember if my 425 kit came with it or not, but I had one on hand and installed it during the build. I never really looked at the one in the kit to see if it was the newer one.
Never had any problems with tail kick yet and running a head speed of close to 3000.
I don't need the latest and greatest. I just need more time to fly what I have.
Helipro 450se, Gaui 200, Gaui 425 x 2, Gaui "HeadHunter 500, Gaui 550
Jerrymac is offline        Reply With Quote
Old 07-11-2010, 07:39 AM   #3
Epoweredrc
so how would you be able to know for sure? take the tail grips off and take out the bearings and look at them?
,B450 w.HS65MG,ZYX Tarrot Head FBL, Billowy Batterys ,MCPX BLack dragon oversky 10a, Blade CP pro BL
Epoweredrc is offline        Reply With Quote
Old 07-11-2010, 08:51 AM   #4
rotorsup
Epoweredc - In the video I mentioned in my previous post, Bob shows the disassembled tail grips and bearings. If you remove one grip from the tail assembly, you will be able to get to the bearings and check whether they match what is shown in the video.
As he points out, there is very little lateral support for the bearings, which makes them prone to binding up at higher rotation speeds. Again, I don't even have my heli yet, and the video is about three years old. Maybe Gaui has improved the situation. I'm simply questioning if this has been a problem for anyone.
Old 07-11-2010, 09:26 AM   #5
Epoweredrc
yeah i some how looked over that video when i downloaded them all and watched them.
looks like mine I just got witch someone got at IRHA last year so it looks just like the video.
Old 07-14-2010, 09:10 PM   #6
fraser1818
Your purchase is one of the finest deals in rc heli's anywhere. The tail works great. The whole heli flies great. I know it's cheap in cost but imo it is by far the nicest flying 500 size heli out there. I fully upgraded one of mine and it is spectacular looking. I also bought mine from heli flight center. After trying mine, 12 other people from our club bought one. Some days at the field it looks like a Gaui convention. Good luck with it.
fraser1818 is offline        Reply With Quote
Old 07-15-2010, 04:49 AM   #7
Mikej
Nice one Fraser - good to hear that you are all enjoying your Gauis - have any of you tried them with 500mm blades yet ? Makes them even better IMHO - you can make the change for about $30 !!!
Mikej is offline        Reply With Quote
Old 07-15-2010, 05:44 PM   #8
rotorsup
Thanks for the info Fraser. The heli came in last night (late delivery from FedEx Home Delivery). Worked on it much of today - and if I had been smart enough to order the pinion, I'd be ready to maiden tonight. I held out hope that my Align pinions would work. I should have known better.
I'm very impressed with the quality. Little things, like the ball link on the pitch slider arm that actually connects to the bell crank (thought I had something wrong till I figured it out). For $80, I'm amazed. Hope it flies as well for me as it does for all of you...
Old 07-15-2010, 06:07 PM   #9
Epoweredrc
What motor you get?
Old 07-15-2010, 07:09 PM   #10
rotorsup
I'm using a Tonix 1620kv motor I had in a Trex 500. With the setup I'm using - 13 tooth pinion on order, I should get a headspeed of about 2600 rpm or so. Hoping this will power it well enough.
Old 07-15-2010, 07:20 PM   #11
Epoweredrc
Oh... alright then, didn't know you had a setup already.
