Old 07-10-2010, 11:28 PM   #1
jaeger
Default atv swash giving a headache
Re building after ground attack its been awhile 9 months since last set up I am doing every thing right center sticks 90 degree servo horns level swash at mid stick, but when high and low stick atvs arent doing a thing I ve been at this for 17hrs straight and I am going mental I ve read the threads etc but something not happening any pointers thank you
Blade400 #1 440 Stock Motor, Phoenix 50 esc Hs-65mg
401 Gyro /Futaba s9257 tail, HK carbons.
Turnigy 2200 35-45c
Blade400 #2 Stock
jaeger is offline        Reply With Quote
Old 07-10-2010, 11:37 PM   #2
Larry227
So when you go to level the swash at low/high stick adjusting the atv's don't move the servos at all? That's odd. Were they damaged in the crash? It's been a long time since I setup from scratch too so maybe it's just something simple and I can't think of it either.
Trex 700 Pro DFC - Compass 6HV - Vcontrol - Neo
#nodroneshere - 104
Larry227 is offline        Reply With Quote
Old 07-11-2010, 01:16 AM   #3
jaeger
These are my settings re bind radio to heli, what ive just found was while adjusting swash at high and low stick to get atvs to work had to jiggle appropriate stick to make atv respond is this a dx6i glitch 24 hrs just figure that out
D/R & Expo
Aile - 0 - 100% 1 - 100% INH
Elev - 0 - 100% 1 - 100% INH
Rudd - 0 - 100% 1 - 100% INH
Travel Adj (all percentages are in both directions)
Thr - 100%
Ail - 100%
Ele - 100%
Rud - 100%
Gyro - 100%
Pitch - 100%
Sub Trim
Thro 0 Aile 0
Elev 0 Rudd 0
Gyro 0 Pitch v34
Gyro
SW-Gyro Pos 0: 25% Pos 1: 77.0%
THR Curve
Normal: L - 0% / 2 50% / 3 - 80% / 4 - 90% / H - 100%
Stunt: L - 100% / 2 - 95% / 3 - 90% / 4 - 95% / H - 100%
Hold - 0.0%
Pitch Curve
Normal: L - 40% / 2 - 45% / 3 - 50% / 4 - 75% / H - 100%
Stunt: L - 0% / 2 - 25% / 3 - 50% / 4 - 75% / H - 100%
Hold: L - 40% / 2 - 45% / 3 - 50% / 4 - 75% / H - 100%
Swash Mix
Aileron - +60% (positive)
Elevator - +60% (positive)
Pitch - +71% (positive) BLADE GRIP FLIP
Mix 1 & 2 are INH'd
Revo Mix
Norm - 0% Up & Down
Stunt - 0% Up & Down
Reverse
Thro-N Aile-R
Elev-N Rudd-N
Gyro-N Pitch-N
SWASH TYPE
CCPM 120
Turnigy 2200 35-45c
Blade400 #2 Stock
Old 07-11-2010, 01:35 AM   #4
Larry227
I don't remember if that was one of the glitches that was happening on these or not but it wouldn't hurt to check if your DX6i is on the recall list from last year.
http://www.spektrumrc.com/Articles/A...ArticleID=1901
There's one thing you could try. Copy your model to a blank model and then bind to that new one and see if the glitch is there too.
#nodroneshere - 104
Old 07-11-2010, 05:50 AM   #5
Dazhim
Jus tossin out there.. have u tried movin the values past 100%
Dx7s, exi 450 pro(I swear it's a trex by now lol)
MSH Prtos: 500 fbl,MSH Prtos 450 fbl
Blackout 250
ZMR 250
Dazhim is offline        Reply With Quote
Old 07-11-2010, 06:07 AM   #6
Wiggen
This is the way this radio works.
To level the swash at low/hi end,just go to the atv/traveladjust. screen.Hold the cyclic stick in the desired direction and at the same time scroll the wheel.If the swashplate isn,t moving or moving in wrong direction just push the stick in the opposite direction and scroll.
Wiggen is offline        Reply With Quote
Old 07-11-2010, 06:27 AM   #7
jaeger
Checked radio numbers its not a dud, wiggling the stick seemed to wake up the servos,had the beast hovering over the deck tonight -1.6c out side, I cant stand it when I get beaten and doing extended hours to get it flying again has fried my brain. This rebuild was a mission to sort out thanks every one for replys. Now time to sleep
Turnigy 2200 35-45c
Blade400 #2 Stock
