| 600 Class Electric Helicopters 600 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
help!!!
My heli = 8==+==+==D. Lmao!! you will become an expert or bankrupt which ever comes first lol |
Why 0.5A? Are you not able to use a smart balancing charger?
Logo 500 SK720, 4025-890, CC ICE 100 T-Rex 600 ESP w/3G - 12S, 4025-630, CC ICE 80HV Blade 400 w/ HS5065MG, CopterX FBL, ICE Lite 50 eRaptor Conversion, 12S, 4035-500, JR 8700g, 3xDS610s |
.5 should take about all day to charge
However 5.0 should in theroy charge in an hour and yes if your charger and supply will let you go to 5amps go for it the MAH of the battery generaly breaks down the charge rate (1c anyhow) 5000 --- 5a 2650 -- 2.6s 1000 -- 1a and so on. 2c and 3 c would double and triple these numbers. 1c is almost always suggested Markus |
.... is that ok?
charging at .5 is like you walking no Mexico. You need to explain yourself a little better. What are you trying to achieve?
TREX 500-neu/kde 1907/1Y -14 PINION-DE 6A BEC-AR6200-JR 3517MG-8900G TAIL-CC 75 ICE MINI V TREX 700E-NEU KDE 1917-12 PINION-PRO BEC-MIKADO BLUE LINE -JR 8717 HV CYCLIC-8900G TAIL-ICE 160-KDE UNIVERSAL MOUNT W/PINION SUPPORT |
#6 |
#7 |
#8 |
Go to your hobby shop dude, we're obviously way over your head here.....
![]() But seriously man, either google it or go talk to your friendly hobby shop to help you understand it.
AMA# 655558Trex 600E, Compass 6HV FBL Head, Microbeast, Inolab DS760MG cyclic, Logictech 6100G tail, CC HV85 ESC, Scorpion 4025-630 |
#9 |
#10 |
nvr mind lmao
#11 |
Its the discharge that kills the battery, not the charging. Mine frequently spikes to 120a current draw while doing continuous tic tocs, and packs come down hot and bloated! Nowadays most packs are rated at 5c charging but its nearly impossible to reach that with our 6s 5000mah packs. The most ive done is 2c charging with my bantam, thats at 10amps charging, takes about 1/2 hour to charge and packs are hardly stressed and feel cold to the touch. Hope this helps.
#12 |
You guys should take it easy on him. He is obviously newer to the hobby and just wants to take care of his investment. I see a lot of posts about people doing things because they are anal that I think are a total waste of time. As long as it is not dangerous let it be if it make em happy. Back to the question... there would be no harm in charging the batteries that slow, it will just take a real long time. But....you said you wanted to charge them over night, I am assuming you would be sleeping. You would be breaking an important rule of charging lipos. NEVER CHARGE UNATTENDED! You can look up some posts to see what can happen. As suggested read up on the hobby, dont just take one persons word.
#13 |
C'mon, if he can't take a small pun with a funny picture from someone he doesn't even know then I don't know how he could survive in the hobby. I get mentally assaulted at my field... LoL
I gave him a great guide to lipo basics. We're all on this site to help each other out, we're just 'warming up' to him
#14 |
Sometimes im thinking this is a joke because he has 88 posts and hes responding to us in the " title" box in the reply screen.
#15 |
That's not entirely true. Lipos take juice in much slower than they spill it out. Hence the 20C discharge but 1C charge, 30C/2C, 40C/5C and so on ratings. So, there's not much margin for error in charge current before going over the limit if you put it that way. One could easily kill a 20C/1C 2000mAh pack by discharging it at 10A and chargin at same current. Generally charging fast is known to cut down battery life. That's why many charge their 2C or even 5C batteries at 1 or 1,5C. Takes a little longer but makes your batteries happier.
On the other hand going below 1C is not worth it. The charge time is much longer but battery life will not increase. |
#16 |
I talked to ThunderPower and they stated that fast charging their G4 batts have no negative long term results.
