Go Back   HeliFreak > R/C Helicopter Support > 450 Class Electric Helicopters > 450 Aftermarket Upgrades
450 Aftermarket Upgrades 450 Aftermarket Upgrades
Old 07-12-2010, 08:55 AM   #1
HEIM JOINT
Default HEIM JOINT Chinese weights for the pro grips
Chinese weights are now in stock for the 450 Pro weighted grips. These will give the same tuning as the original weights on stock grips.
PM me for purchase info.
HEIM JOINT is offline        Reply With Quote
Old 07-21-2010, 09:31 PM   #2
E-fanatic
What is it, if you dont mind me asking?
: HKGT450pro
:Align 450 pro, hs65mg cyclic servos, align 450M motor, quark gyro, outrage os7654T servo, Ice lite 50, Align CF blades
:3dhs planes, 42 and 51 inch slicks,and 72in Extra 330 SC
E-fanatic is offline        Reply With Quote
Old 07-22-2010, 06:10 AM   #3
HEIM JOINT
Default What is it?
They are custom tail blade bolts and nuts that are designed to reduce the tail rotor pushrod force to an optimum level to reduce the strain on your tail servo.
I make them for all T-rex helis and others. The Align weighted tail grips on the 250 and 450 models also reduce the pushrod force but not to the optimum levels so I have weights designed for them also.
you can see the concept and how they are designed and tested on this T500 video
Old 08-16-2010, 04:27 PM   #4
CoolKD
Wow, great test. Nice to see some actual numbers to paint a clear picture of whats going on with and without weights. Wery nice man
Blade MSR, MCPX v2 & 400 3D NightRig
Align Trex450 pro. KDE FBL Head & BatTray,MKS DS95,FutabaBLS257,BeastX, ICE50, CC BEC, Scorpion6
Align Trex700LE N. LYNX Clush/Liner, Quark,Hatori SB20FH-2,O.S91HZ
CoolKD is offline        Reply With Quote
Old 08-21-2010, 12:17 PM   #5
Rishelman
Very cool!! Thanks for taking the time to do your little "experiment". Now, where can I get some weights for my 450 clone??
Rishelman
Rishelman is offline        Reply With Quote
Old 08-22-2010, 09:42 PM   #6
newflyguy1
Default in need of a set of your wieghts.....
i sent you a pm and just wanted to follow up to see if you have a set of your chinese wieghts available for me to purchase. i would like 1 or 2 sets for my 450 se v2 tail grips. i also pasted a few links, in my pm, to describe the grips that i have so we can both be sure that i get the correct ones that i would need.
thanks for your time,
newflyguy1
newflyguy1 is offline        Reply With Quote
Old 08-30-2010, 01:05 PM   #7
momo2008
how much are these things? would like to get one.
momo2008 is online now        Reply With Quote
Old 09-02-2010, 08:27 AM   #8
dude7422
he quote me 16.00 plus 4 .00 shippping i could buy 2 complete pro tails that come factory with the chi weight mod cast into the part for that price HEIM dont be to peved at china for taking your idea and running away with it thats what they do
Dee Dee Dee
dude7422 is offline        Reply With Quote
Old 09-02-2010, 08:34 AM   #9
Inverse
If your weights are as professionally put together as your T250 tail preload kits, I'll recommend you to anybody.
Inverse is offline        Reply With Quote
Old 09-02-2010, 10:12 AM   #10
HEIM JOINT
I am not peved . It is not my idea to begin with. I learned about the whole topic on HF to begin with. All I did was design and test weights to give the optimum reduction in tennis raquet effect that you could just use as a blade bolt and nut. What I have heard is that the stock tail blade grips with my original weights performed better than the new weighted grips by themselves. So as a service to my fellow HF members I designed a weight for the pro/sport tail that gives the same tuning as the original setup. If the weighted grips were so good why do they still need a chinese weight that is about 90% the weight of the original?
As for price I machine most of these on a manual machine in small batches(20-60 sets). Not a screw machine in china. Yes these could be a lot cheaper if I had 10000 run on a screw machine. But since I only sell few hundred a year that wouldnt be a great idea.
Most guys are greatfull that I bother to make them at all.
HJ
Old 09-02-2010, 11:38 AM   #11
HEIM JOINT
Thanks for your support.
Old 09-02-2010, 06:55 PM   #12
Inverse
Hey, it does what it says on the tin, if it were crap I'd tell you that too
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Prôtos 500 - MSH Brain
Tarot 450 Pro - AR7200BX
Spektrum DX8
Old 09-09-2010, 11:30 AM   #13
SAR1
Where can I find a complete listing of the "others" that you make these for?
Mïke
Tarot 450 Pro, Typhoon 2215/HW 40A Pro, 3xHS65HB, Quark/DS520, KBDD paddles/tail DX6I/AR6200
SAR1 is offline        Reply With Quote
Old 09-09-2010, 11:33 AM   #14
HEIM JOINT
Trex 250 non weighted grips
Trex 250 weighted grips
Trex 450 SA
Trex 450SEV2
Trex 450 Pro or Sport weighted grips
Minititan 325
Trex 500 STOCK PLASTIC
Trex 500 KASAMA
Trex 500 ALIGN METAL
Trex 600 STOCK PLASTIC
Trex 600 KASAMA
Trex 600 QUICK UK
Trex 600 ALIGN METAL
Trex 700 STOCK PLASTIC
Trex 700 KASAMA
Trex 700 QUICK UK
Trex 700 ALIGN METAL
Vibe 50 STOCK PLASTIC
Vibe 90 STOCK PLASTIC
BEAM E4
GAUI 200 V1 & V2 (OUT OF STOCK)
T250 PRELOAD SPACER SET
Old 09-09-2010, 05:35 PM   #15
Inverse
Can we come up with a solution to the play in the pitch slider? It's the only place I have significant play left?
Spektrum DX8
Old 09-10-2010, 07:17 AM   #16
HEIM JOINT
Unscrew the slide shaft from the "T" arm of the pitch slider. (be carefull it is easy to crush the flatted end of the slide shaft). Remove one of the bearings from the bearing holder. take out the washer that is between the bearings. Sand the washer thickness down. Take about .005" off. Make sure you keep it parallel as you sand it. clean the parts and reassemble. Put some low strength thread lock inside the "T" arm threads.
As you tighten the slide shaft into the "T"arm feel for the axial play in the bearing assembly and carefully aproach the point of zero play. If you go too far the bearings will feel crunchy andyou need to back off a little. If the slide shaft gets tight and you still have some play then take some more off the washer. You can eliminate the washer but then you are totaly relying on the thread lock to maintain the preload setting.
Hope that helps. HJ
Old 09-10-2010, 08:36 AM   #17
Inverse
I'll try it tomorrow and let you know how I go.
Spektrum DX8
Old 09-22-2010, 01:33 PM   #18
lb4131
HJ, Can you send me a PM with what is included, cost and shipping info? Looks like I can't send you a PM yet. Thanks.
lb4131 is offline        Reply With Quote
Old 09-22-2010, 01:42 PM   #19
lb4131
looks like I left out the type I need... Sorry Align 250 with the standard grip non-weighted grip
Old 09-23-2010, 11:08 AM   #20
lb4131
HJ, HF won't let me reply to your PM until I get a 3rd post in. I'll try to reply after this one.
