Old 11-28-2006, 01:36 PM   #1
staplegun
Default Wobble problem
I have noticed a wobble that is not related to something being out of ballance.
When I transistion from forward flight to hover, I get a wobble that dissapates over a little time (10 - 30 seconds). Is this something that can be attributed to dampening in the head?
I am running an AL 600 combo, with the align ESC and motor, using the grey dampers, SAB 600mm mains, Align tail.
I took a quick trip to the flying field this AM for flight #5 and was able to get some decent flying in (no thrashing or 3d). I flew a couple of hard climb outs, and circuits to approaches. This is where I noticed the wobble.
Time for a "Hover" break... http://worleybird.com/fly/HoverBreak.wmv
Huh, What... ...and it's raining parts.
staplegun is offline        Reply With Quote
Old 11-28-2006, 02:09 PM   #2
king kong
probably the head speed. what's your throttle curve, battery, blades, pinion, and pitch?
Make it go BOOM
Team Flightpower
king kong is offline        Reply With Quote
Old 11-28-2006, 02:14 PM   #3
erniefritz
check your headspeed... wobble is usually because the HS is too low if you are running stock gearing you should be at 90% or above on the throttle in hover , most run a straight 100% in idleup , also make sure your ESC is getting 100% throttle at full stick either by reprogramming and/or expanding your endpoints on your throttle endpoint adjustment...
erniefritz is offline        Reply With Quote
Old 11-28-2006, 02:19 PM   #4
Finless
Team Taco VP
Yep I am with Kong here.... Head speed is probably low in relation to amount of pitch in the hover.
Finless is online now        Reply With Quote
Old 11-28-2006, 05:27 PM   #5
marcelino
The grey dampeners are the soft ones, aren`t they?
It`s possible to get wobble, if your Head is to soft for the high headspeed.
I would suggest both: increase and decrease your headspeed and see what happens, then insert the black dampeners and try the same.
Marcel
marcelino is offline        Reply With Quote
Old 11-28-2006, 05:59 PM   #6
staplegun
Just took it out for flight #6. I really like this bird
Adjusting the Throttle curve fixed the problem.
Former T-Curve 0-40-80-90-100
New T-Curve 0-45-90-95-100
Idle up 1 100-95-90-95-100
Idle up 2 100-97.5-05-97.5-100
Pitch -9 to +9
Normal P-Curve 40-45-50-75-100
Idle ups 0-25-50-75-100
Thanks for the advice.
Old 12-24-2006, 09:24 AM   #7
avatar71
rookie question perhaps but, what is the purpose of the "05" throttle setting in idle up 2?
thanks,
dave
avatar71 is offline        Reply With Quote
Old 12-24-2006, 10:41 AM   #8
stevehonn
I would guess its a typo and should read '95', this is the usual mid-stick setting for throttle in idle up 2.
Steve H
Trex 600N Sport, 700N , Trex 250, Beam E4, Trex 550E, Raptor E550, Mikado Logo 500 3D, now a happy user of Futaba 10CG
stevehonn is offline        Reply With Quote
Old 12-24-2006, 10:43 AM   #9
stevehonn
Steve H
Old 12-24-2006, 11:04 AM   #10
avatar71
ok, good, I figured I was a challenging throttle curve at first...
Old 02-10-2007, 03:13 PM   #11
Steve Rogers
Man I LOVE HeliFreak!
Just toook my new 600 to the field to try it out & wobbled like heck! Brought it home & went through EVERYTHING to no avil. Get on the Freak & WaLa!
Bumped my curvs up to what staplegun did & that got the biggest majority of it out. I think I'm going to chunck the stock gear & go for an 11 tooth!!
Steve Rogers is offline        Reply With Quote
