| Hitec Radios Hitec Radios Support |
#21 | |
Hello to you to, glad you like it ? ........ I think The spreadsheet has no password !, so you can add all you like, I did it that way so all can use it as they like and not to restrict it to what I put into it and if Hitec added anything it could be added, like the T.Limit. Those annoying drop-downs are there for a reason as they are the imputable numbers in the Aurora for each field, why would you want to input a number that you could not put in the TX. Anyways you can just type the number in, you don't need to use the drop down so long as it is an allowable number. If you can use Excel, you will know how to change this. Hope this helps |
#22 | |
I was trying to add Co-Pilot to switch E and went to the list sheet to add it there and that entire sheet is password protected, I then did it by trashing that cell and typing it in by hand. I have a similar situation on the gyro switch (A), where the Up /Down selection lists only allow On/Off, when what I need is Rate Mode and HHold Mode. Also the Flight-Conditions list does not include "Normal".
Craig If you're not living on the edge, then you're taking up too much space |
#23 | |
That's ok we all have bad days Ok I thought you where talking about the worksheets for each model and not the list which I did password so I no one accidentally changed things if they did not know what they are doing as it would wreck the spreadsheet. Apart from the co-pilot one, the rest are there they are just named different to match the Aurora. As far as the on/off, you can selected Rate in one box and HHold in other then have on/on in the up/down boxes. More than happy for you to customize how you would like it, will PM you the password |
#24 |
OUTSTANDING!
Semper Fi, Gunny. |
#25 |
Thanks, glad you like it
#26 |
Thank You for taking the time to do it and to post it
Nice layout. I like it |
#27 |
#28 |
Wow, never thought when I made this it would get over 5000 hits
