Old 07-23-2010, 03:22 PM   #1
JiriK
Default One-way gone bad
I flew two flight with my fbl- protos today. Before third flight I noticed that the one-way bearing on that 14t pinion had jammed solid.
So I came home and took it apart. Heres what I found.
One-way bearing had broken in pieces and cut grooves on the adapter.
Any ideas on what went wrong? Bad setting / bad bearing / bad luck?
Setup is 6S Lipo (Turnigy 40-50C 2200)
Hyperion HS3026-0880 motor and Jazz 80 esc.
So it has some punch..
JiriK is offline        Reply With Quote
Old 07-23-2010, 07:47 PM   #2
terrabit
It's probably just not pictured but your top bearing isn't there.
terrabit is offline        Reply With Quote
Old 07-23-2010, 08:21 PM   #3
Mentalic
Pinions.... Heres a vote for a 2x stronger small pinion one way system. I'd like to run one but I'm not touching this setup.
Tach'd mine today, wow it was at 2900rpm ID1, ID2 just over 3000! Guess the crazy hot weather has the lipo's cranking out the power. Its very snappy.
Mentalic is offline        Reply With Quote
Old 07-23-2010, 08:45 PM   #4
JiriK
I took both support bearings out of the pinion when I was investigating what was wrong.
Both bearings look ok. One seems to spin just fine, other one not so well.
Old 07-24-2010, 12:32 AM   #5
Lplate
Do you think the 3rd bearing support in the stretch conversion kit will help?
I sure hope Corrado releases the 3rd bearing support with drill bit+jig for non-stretch flyers.
Lplate is offline        Reply With Quote
Old 07-24-2010, 04:00 PM   #6
Mentalic
I don't think it will help with the type of wear pictured. A much harder shaft would help and a larger/additional one way to help spread the load would help.
Old 07-28-2010, 02:43 PM   #7
JiriK
Im back at 15t pinion..
But what is that duck quack -like sound during high power climbs, tictocs etc?
Belt too loose and slipping or is this one-way bearing slipping?
Dont remember hearing that sound so much with 14t pinion, but then the belt was tighter too..
Old 07-28-2010, 02:50 PM   #8
terrabit
I suppose it could be either but I'd guess it's your belt slipping.
Old 07-28-2010, 07:06 PM   #9
Mentalic
Sounds like a belt slip to me. More often the pinion lets go completely, its hard to miss that.
Old 07-29-2010, 04:11 AM   #10
whisperdancer
The 3rd bearing support is only for 12T, 13T and 14T.
The bearing is to small for a 15T adapter, unless MSH comes out with an adapter that has a small diameter on the top.
MSH Prtos CF FBL Stretch
E-flite HABU 32, Parkzone HABU 2
Ikarus F3A
Multiplex Parkmaster 3D
whisperdancer is offline        Reply With Quote
