Go Back   HeliFreak > R/C Helicopter Support > Synergy Model Helicopters
Synergy Model Helicopters Synergy Model Helicopters Support
Old 07-26-2010, 05:39 AM   #1
jaxrotor
Default N5 Auto one-way locked
After about a half gallon of flying around easy breaking in the motor, I did a few autos and noticed this thing sucked at autos. Thought it was just me,the weight of the heli or the blades I was using. Turned out the auto bearing was locked. Anyone one else having trouble with the one-way?
www.jaxrc.com
jaxrotor is offline        Reply With Quote
Old 07-26-2010, 02:35 PM   #2
Tommy Wagner
I had the same thing happen to me but I don't remember greasing the one way so I just changed it out.
Tommy Wagner is offline        Reply With Quote
Old 07-26-2010, 03:54 PM   #3
chugga-bug
Lots of people having problems over here. Some other good tips too. Have a read through these; http://www.rcheliaddict.co.uk/synergy-n5/
chugga-bug is offline        Reply With Quote
Old 07-26-2010, 05:41 PM   #4
jaxrotor
Good reading...Thanks
Is something in the works for a fix to this?
I will check the size of the sleeve.
www.jaxrc.com
Old 07-26-2010, 07:40 PM   #5
Tommy Wagner
I had to make a emergency landing in some tall grass (pressure line came off pipe) broke 3 of the bolts holding the landing skids in the mounts that was the only damage. The bad part was that when I tried to drill them out the bits would just slide off the bolts and go into the the mounts so I had to buy new mounts $18 x 2
Old 08-06-2010, 10:18 AM   #6
EO19
Mine has locked up also.
EO19 is offline        Reply With Quote
Old 08-16-2010, 09:35 PM   #7
00boto
Guys,
We are aware of this issue and are working on a solution. Some things to try in the mean time.
- clean all of the grease out of the one way a try a light oil
- lightly sand one way sleeve down to 11.98mm
Hang in there we get to the bottom of this.
Matt
00boto is offline        Reply With Quote
Old 08-16-2010, 09:42 PM   #8
Justin Pucci
Matt,
Thanks for the update...I'm sure you'll figure it out soon enough! What is the effectivity of this issue? With the new kit that just bought a few weeks ago, should I expect to have the same problem? I haven't gotten to that part of the build yet, but I'll be sure to check when I do.
Justin Pucci is offline        Reply With Quote
Old 08-26-2010, 08:49 PM   #9
Epoweredrc
That sucks, but all new things have issues there are no two just alike.
XK252,K120,Cpx450 ZYX,,Trex600 Beastx, Gremlin,POD Racer, GLH,Whipit,Z-84, Elelctric Shock AMA 27 yrs.
Epoweredrc is offline        Reply With Quote
Old 12-31-2010, 08:30 PM   #10
visionplay
Has this issue been sorted Matt.
I have one of the newer kits and My Oneway is locked Up.
I done the mods and still no good. What are my options?
John
Logo 600, Vbar, Jive 80HV, Pyro 700, BLS.
Synergy N5, OS55, Vbar
Mini Protos FBL, Vbar, YGE, 3S TP 65c's.
visionplay is offline        Reply With Quote
Old 12-31-2010, 10:42 PM   #11
flyboy907
a new one way is in the works and will be available soon
flyboy907 is offline        Reply With Quote
Old 01-01-2011, 02:57 AM   #12
visionplay
Sweet.
Thanks for the info...
John
Old 01-07-2011, 11:59 AM   #13
00boto
Check with your local distributor( Extreme Helis in AUS)
He should have some of the newer one way hubs in stock. The new one way is coming in all new kits now, you may have gotten one of the very last kits that had the original one way. Another note for all one way hubs, if you are flying in temps below 40 degrees, make sure you clean the grease out of the one way. The grease tends to thicken and causes the roller needles to stick. Clean the grease out and use a decent oil. Also the elevator bell crank inner and outer are coming tapped to 4mm in all new kits.
Thanks!
Matt
Old 01-07-2011, 02:40 PM   #14
nwmtech
New one-way looks great! Thanks Matt. Should be doing some mid 30* testing this weekend.
nwmtech is offline        Reply With Quote
Old 01-09-2011, 01:39 AM   #15
Punishment
mine was locking up as well there is no need to buy a new one just clean it out like mat says and give the sleeve a bit of a rub down with wet & dry and fill it full of tri-flo oil had 6 flights on it so far after fix and no problems it only takes a hour of your time.
thunder tiger g4 nitro
thunder tiger g4 e720
Punishment is offline        Reply With Quote
