Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X5
X5 Discussion and support of the Gaui X5
Old 07-26-2010, 05:34 PM   #1
JoAs
Default X5 Main Blades
Hi!
I just got my Gaui X5 and start building it tomorrow. I bought Edge 553mm main blades from 3D Masters and asked from "Gaui Team" (or whatever that was...) that will those fit to X5. They say that it should be okay.
In the box it says:
"Main rotor blades 500mm to 530mm"
So my Edge blades are 23mm too long?
My setup:
Cyclic: Savöx SC-1257TG
Tail: Futaba GY520 + Savöx SH-1290MG
Motor: Scorpion 1820W/910KV
ESC: Gaui 100A
Main blades: Edge 553mm
JoAs is offline        Reply With Quote
Old 07-26-2010, 05:58 PM   #2
torana74
I think they are too long in stock form mate They will hang over the tail blades and run a big risk of touching. I use the Edge 553's on my other Gaui's and love them and wish i could on all my helis.If you really wanted to use them,,, get a hirobo scedeau boom,cut 30mm longer than stock X5, arrow shaft for TT and a longer tail rod.
To be straight up,,,, the X5 is a rocket with the stock 500's. We'll have to hit up Edge to start doing 520's
Vas
GAUI X7, GAUI X5 all vbar.TT 12S Hurricane 550 beastx
GAUI
Field Rep, Team Empire Hobby
torana74 is offline        Reply With Quote
Old 07-26-2010, 06:11 PM   #3
JoAs
Okay, thanks a lot!
I will try X5 with those stock blades. Have to try to sell these 553mm blades for someone who has Align 550, I think those will fit for it.
It is strange that I could not found blades like 500-530 from 3D Masters, there is only some 425 and next one is like 600mm..
Same on tail blades, found only 75mm and 92mm, but not 82mm.. But that man in Gaui tent told me that those stock tail blades are very good... Hard to believe but let's see..
I just dont want to crash that becouse of some crappy plastic blades.
ps. sorry my bad english
- Johny
Old 07-26-2010, 06:33 PM   #4
torana74
Johnny, have a look at my vids... that is a total stock setup,, blades and all.
550's will fit alot of helis. Hurricane,logos,outrage etc etc etc
KDBB make 85 tail i'm sure.... funkey aswell. Just have to look around. So far for me,,, the tail has been rock solid on the X5. Actually the best tail i've had on any heli
Vas
GAUI
Old 07-26-2010, 07:22 PM   #5
mjbrands
I also bought a Gaui X5 at 3D Masters last weekend. I also got some 503 mm Maniac blades, as I didn't realize kit came with some pretty nice CF blades. I put on some bright yellow Outrage tail blades, as I like a visible tail. The Outrage blades have the same length and root width, but they do have a bit more surface area.
The stock tail blades seem pretty okay - they look and feel fairly similar to KBDD blades IMO. Both the Gaui and the KBDD tail blades seem a bit less flexible than the Outrage ones I put on.
I think 85 mm tail blades (such as meant for the Thunder Tiger) should work well to - however, I think 92 mm blades may be a bit too much.
mjbrands is offline        Reply With Quote
Old 07-29-2010, 06:33 PM   #6
jczankl
Default Edge
Edge Rotorblades are in the process of making 523mm FBL and FB should be available in August. Just around the corner :-)
jczankl is offline        Reply With Quote
Old 07-29-2010, 07:19 PM   #7
torana74
Thanks for that. Is great new
I've been hassling my dealer but haven't heard anything.
Vas
GAUI
Old 08-02-2010, 01:21 PM   #8
nexter
Have anyone heard or seen any new info about this?
nexter is offline        Reply With Quote
Old 08-02-2010, 05:22 PM   #9
torana74
My mate is sponsored by Edge and asked to see what's the go with the 523's
This is the response he got for me.
It is true that we are working on a 523mm blade. The FBL version will be the first to be availible then the FB will follow.. I do not have a timeframe at the moment but I believe we will start getting small numbers over the next month or 2.
Hope this helps.
Vas
GAUI
Old 08-03-2010, 04:36 AM   #10
nexter
Hope this helps.
Vas
NICE! now we know that they are on the way. just have to wait and see when they pop up in the web shop's or at my LHS if I am lucky
Thank you Vas for getting some answers
Old 08-03-2010, 08:21 AM   #11
torana74
thanks nexter but if it wasn't for jczankl, i/we wouldn't know these were coming.
Can't wait as i think they'd be awesome. I love my 553's and the oooooomph they have.
Can only see the 523's being just as good.
me want......
Vas
GAUI
Old 08-20-2010, 02:38 PM   #12
nexter
Edge have now released there 523mm FBL Blades, weeee!
Old 08-20-2010, 05:53 PM   #13
torana74
thanks nexter Hopefully the flybar ones aren't too far away. Or we can just go vbar and be done
Vas
GAUI
Old 08-20-2010, 07:45 PM   #14
mjbrands
I just bordered my FBL head and battery brace set from Infinity Hobby. Looks like I can use that Vbar unit I still have after all
Old 08-21-2010, 12:06 AM   #15
3DBEAM
what would be the difference between the fb 523,s and the fbl 523,s ?
Ely-Q Field Rep.
Gaui X5 Field Rep.
RJX Xtreme Helis
Beam 450 pro
3DBEAM is offline        Reply With Quote
Old 08-21-2010, 03:17 AM   #16
nexter
The difference between FB and FBL blades is the FBL blades are slightly heavier at the tip and will therefore give a little more stability for a FBL heli.
but you can use FB blades on a FBL heli and the other way around to if you want. all of this just might come down to personal preference as a lot of other things in this fine hobby of ours.
Feel free to correct me or add anything. (i know you will anyway)
Old 08-21-2010, 04:56 AM   #17
torana74
[QUOTE=nexter;2279252
Feel free to correct me or add anything. (i know you will anyway) [/QUOTE]
Nexter, correction. You are correct
Thanks for the explanation
I asked this my mate this morn and was told usually the flybar version ships 2 weeks after, So fingers crossed it will be soon.
Vas
GAUI
Old 08-22-2010, 05:54 PM   #18
insectskate
OK. So they are out there. Great! Now where do I get my grubby little hands on a set?
Austin
Gaui X5 sk720 STOCK MONSTER!!
MA Furion 450 sk720
Fly it like someone else is paying for it.
insectskate is offline        Reply With Quote
Old 08-23-2010, 05:04 AM   #19
nexter
Ready Heli have them in stock, dont know if anyone else have them yet. I only found them at Ready Heli.
http://www.readyheli.com/LE-523FBL-E...n_p_37280.html
Old 09-09-2010, 03:01 PM   #20
terrabit
Anybody heard anything about the SAB 530's? They are listed on SAB's site but I can't find them anywhere?
terrabit is offline        Reply With Quote
