Old 07-26-2010, 06:58 PM   #1
weelee
Default Head speed
I have a 5000KV motor on 12T pinion. Headspeed is said to be about 5200 at 100%throttle. What should it be? I have the plastic blades and a set of carbons.
Cheers
Chaos 600 FBL (BeastX)
Compass Warp 360
Blade MCPX BL
QAV500 FPV QUAD
weelee is offline        Reply With Quote
Old 07-27-2010, 10:54 AM   #2
bwoollia
5000kv X 11.1V x12t / 120t X 90% efficienty = 4995RPM. Depending on your motor, you're likely less than 90% efficient. I'm using the Turnigy 4800kv motor with a 12t pinion and my headspeed is measured at 4450RPM.
bwoollia is offline        Reply With Quote
Old 07-27-2010, 11:06 AM   #3
weelee
Cheers i was wondering if anyone was going to respond. So with Carbon blades i should be fine. What about the plastic ones?
Compass Warp 360
Blade MCPX BL
QAV500 FPV QUAD
Old 07-27-2010, 11:10 AM   #4
bwoollia
Not sure what they are rated for. Why bother?
Old 07-27-2010, 11:15 AM   #5
weelee
Just for set up. Don't want to wreck my new CF blades in the first flight because something went wrong. I'd rather trash the plastics.
Compass Warp 360
Blade MCPX BL
QAV500 FPV QUAD
Old 07-27-2010, 01:12 PM   #6
bwoollia
Maybe lower your throttle curve for the initial setup, then install the CF's for 100% flat and final setup. Not really sure what the plastics are rated for.
Old 07-27-2010, 03:03 PM   #7
dze
you'll be fine with plastics on the 250. i guarantee the carbons will break before the plastic ones do .. the decision on plastics and carbons on my 250 are about response not headspeed .. carbons have a faster response, also on mine anyway switching between blades can throw the whole setup off and how the tail reacts so i would just put on whatever you plan on flying to dial in the bird .. want a more forgiving cyclic feel go plastic, want it real crisp use carbons ..
dze is offline        Reply With Quote
Old 07-27-2010, 07:23 PM   #8
brianr058
wow, guarantee huh? thats a big statement. I wouldn't use anything but carbons at those headspeeds as they may fly apart. I don't no about you but I wouldn't wanna catch a blade at that speed or anyspeed for that matter!
brianr058 is offline        Reply With Quote
Old 07-29-2010, 06:31 AM   #9
UH1H
Aling caution not to go over 4660 head speed..you guys are looking for trouble...
UH1H is offline        Reply With Quote
Old 07-29-2010, 08:07 AM   #10
snjbird
I'm not sure why you think you need 5000 HS, I fly mine at 4500 in set rpm mode with a castle creation ESC, I have the Scorpion 2208-3600 motor and a 16tooth pinion.
The motor you are using is probably a 2S motor, like on a Guai. But I would think that the CF would be the only blade I would spin that fast?
snjbird is offline        Reply With Quote
Old 07-29-2010, 08:59 AM   #11
Matt Nasca
For a very brief time I ran a Scorp 3900kv and a 16T pinion, while I was waiting for the 15T to come back in stock after an unfortunate grub screw stripping. I tached the HS at 100% and it was 5200ish. I flew it for 2 packs that way and was nervous the whole time. I later reduced it to 85% which brought it back to the 4500-4600 range which is a great HS.
The plastics "probably" won't break at that speed but they will track like crap! You may run the risk of a crazy vibe and tracking issues that may cause problems because they are so flexible. I wouldn't even consider of running the plastics at 4500+ HS on mine
GAUI X7 - GAUI X5 - GAUI NX4 - GAUI X4 II - GAUI X2 - All on VBar 5.3 Pro
GAUI USA / Scorpion Motors & ESC / Scorpion Competition Packs 65C+ / Spin Blades / YS Engines / VP PowerMaster
Matt Nasca is offline        Reply With Quote
